Base 991.2 Spring Upgrade
Old Feb 21, 2021 | 12:57 PM
stout's Avatar
stout
Originally Posted by Irish996
At higher speeds the car can become very unsettled over undulations and bumps especially when already loaded up going through a bend etc.
Road, or track? Track is easier and more one-dimensional. Road is trickier. Stiffer springs may or may not help with that issue, as what you very well may be looking for is compliance. It's all a compromise, if you watch David Donner's run up Pikes Peak (under a thread called "New 991 film" in this forum), you'll see the compromise he chose to avoid losing big time on the smoother lower sectors. I've been road testing cars on mountain roads like that for years, and what matters most is not perfection in one condition or the other—because you won't get perfection in both—but predictability, which feeds driver confidence.
Would be interesting to see what Tom and/or Mike at TPC might have to say there, as you're already using DSC.
Old Feb 23, 2021 | 12:24 PM
Tom@TPC Racing's Avatar
Tom@TPC Racing
Premium Sponsor
Hi Folks, has anyone upgraded the stock springs only? Perhaps to S springs or something else?
Car is experiencing far too much body roll at higher speeds and need to stiffen things up without going coil over.
Already have DSC installed with GT3RS file loaded.
Not interested in dropping car too much from stock due to driveway and speed ramps.
Any advice appreciated.
The DSC GT file already commands the shocks to their max output during higher loads. If the excess body roll wasn't there before and its here now it could be that a shock(s) is worn out losing its damping output, or a broken sway bar link.
If everything checks out fine and you want more roll stiffness then add stiffer sway bars. Stiffer spring help, but stiffer sway bars are more effective in specifically targeting body roll.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
Old Feb 23, 2021 | 12:28 PM
Tom@TPC Racing
Premium Sponsor
Spot on. Its all about having versatility of the intended usage.
