Tire Advice
Tire Advice
New to me first Porsche 2017 991.2 C2S. I live in Vegas and will drive the car daily all year. Currently running P Zeros. I will stick with summer tires all year. Any comments/recommendations appreciated. My last car was a 2018 BMW M2, real fun, but nothing like the thrill of driving the 911. THX
PS4S for summer/rain but not cold weather. Good all-around performer. Perfectly fine for aggressive back road and normal street driving but they will de laminate if you do AX or track. I use them for my street tire.
But while we’re here, can someone explain to me why when I do the search on Tire Rack it presents several results with what appear to be the exact same model of tire (PS4S) or is there a difference I’m not seeing?
Also, can we clarify whether it’s:
PS4S = Pilot Sport 4 S
PS4s = Pilot Sport 4 (plural)
or some other similar nomenclature.
Another South Floridian here too with same vehicle. I’m just here to count how many replies for Michelin PS4S.
Michelin Pilot Sport 4S. Not plural.
GT3FZS (01-31-2021)
Have owned Pirellis before and just got rid of the Pirellis on my Merc SUV due to cracking and belt failure (they had plenty of tread). No more Pirellis for me.
The Merc got Michelin truck tires, they're not as sporty but much more comfort and quiet, it's not a sports car.
The 911 came with PS4S from the factory, they're relatively quiet, the car rides well enough for long trips even with the low profiles (I've taken several). Those are the ones I would get again.
If you are DD the car, you will have to buy approximately one set of new rear tires before you need to replace the front.
The Pzero tires are non directional, so you can swap them from side to side for rotating. The Michelin PS4S are not.
Most people hate the Pzero tires, but the newer ones don't seem to be that bad. I have no complaints.
Longevity is a fantasy question... you will probably damage a sidewall and need to replace 1 or both tires at some point before they actually wear out. Those who do get a full cycle out of a set, usually brag about it because it is rare and unusual.
I got 10,000 miles on one rear tire before it died a tragic death. The other was pretty well worn out, so I replaced both. One of the front is original and still good. The other was new after only 2500 miles(sidewall puncture). If the front tires make it, I will replace them all when the rear tires go in about 10,000 more miles. Most likely with Michelin Pilot Sport 4S as they are a newer design/release for the Porsche. Again, I could be wrong about the Pzero design of the tire, but it seems like Michelin is working more at producing an engineered tire specifically for our 911s.
The Michelin tires, N Spec, come a specific tread for the Porsche, Lamborghini and a few other makes. It is weird, but yes there is a specific tread pattern for the Porsche. You have to be careful when you order them.
I think the Porsche Michelin PS4S tires have a sidewall perimeter rubber curb guard to protect your rims from curb rash. The Pirelli Pzero tires have the curb guard in case you were wondering.
For DD, that is about it. Tire pressure and maybe check for wear to make sure you do not need an alignment. Your inside rear tires will probably wear faster than the outside rears. It is a pain to inspect, but try and look closely every one and a while. Enjoy your ride! You have great country to explore in a Porsche! At least you don't have to invest in winter rims and tires. That is another level of complication and expense you dodged.
diggiddi (03-14-2021)
