Rear Quarter Window - loose?
I actually removed mine and added a 1/16" rubber strip to bottom of glass to eliminate a rattle which turned out to be the rear hatch bumper not being adjusted correctly, lol. I would not touch it, You can push on any 911 and that glass is moving unless a nut like me put rubber under it. Yea it's a cheap crappy design on any car no less a 6 figure car. Only two bolts can be tightened behind the b pillar. You tighten too much and you bust glass. I forget the torque value but it like 16 ft-lbs. get b-pillar cover off is incredibly difficult due to a clip. again look at rattle post and he does an exceptional job explaining how to remove. Again I wouldn't touch it....
QuietFiend (04-11-2023)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Yeah I think I will just leave it alone since so far I haven’t really experienced anything bad happen with it. Since my car has the lightweight glass i’m just gonna leave it or let the dealership work on it(in my case my dealership wanted me to replace the damn quarter glass!!)
Also I found the thread you were talking about earlier. Im posting it here incase people need some reference:
https://rennlist.com/forums/991/1308...l#post18241832
