Rear Quarter Window - loose?
Quick sanity check. I have my car in for some service and mentioned that my rear quarter windows are loose. When I push on them (either in or out) when cleaning, I can literally feel them move - there is a lot of play and it feels like I could just push them all the way out. The SA says he has heard this is normal but will have the techs check. Seems odd to me so I am looking for some feedback. For reference I have a .2 coupe. What say you Rennlist?
I notice the same thing on my 2017 991.2 Carrera
Bummer - was hoping I was the outlier but this still seems odd to me.
Pretty normal, the rear side windows are quite loosely held in place. Two screws on one side, I think the front, and a few guide tabs elsewhere.
Thanks!
ditto my 2012 C2S. consider yourself lucky if it doesn't make a terrible rattle/noise when temps drop below 60 degrees. mine did and it drove me nuts. spent about an hour pin pointing exactly where it was coming from and exactly where to jam in a soft rubber grommet to make it go away. about a dozen tries until i nailed it. feels firm now...but not too firm as it needs to flex a little bit. internet search revealed it's fairly common along with a process to fix it properly. i chose the grommet jamming method instead. quicker and way cheaper =)
The 997 design is even worse. Held in by rivets. But if you ever need to remove the window seal you need to remove the rivets, which then get stuck in the double walled fender and create outward dents. Sometimes the rivets can apparently just come out on their own as well. The 991 design, maybe while not as secure, eliminates that risk.
The entire hood of the car is held with two hinges and one electronically actuated clasp -- a much larger surface area subjected to much higher pressure differentials, yet it's just fine.
I wouldn't think too much into it.
Ditto on my 2013 991.1 C2S. I was surprised to discover this past summer the right-rear quarter window moved in and out while cleaning it. But the other side's window did the same thing, so I assumed it was normal (perhaps prevent the window from cracking when the body flexes?).
Hi guys I'm having the same problem on my Drivers Side Rear Quarter window on my 2019 Carrera T.
I'm devasted cause I thought this would be a simple fix but taking it to my Porsche Dealer they mentioned that the driver side rear quarter window will need to be replaced.
Sales Advisor mentioned that the "Lightweight Glass is seperating" and it will cost is $2,828.61 to replace.
Basically my symptoms are the same in this thread. theres a little play when i push down on corner where it meets the bottom window moulding kinda like its loose at the bottom corner. Isn't the fix usually some screws/bolts that just need to be tightened behind the b pillar trim?
Need some help here guys cause this just totally ruined my day and my first experience owning a Porsche 911.
Thanks Guys
Thanks Guys
Guys the rear side windows are cantilevered off two bolts in "B" pillar and then a T-Piece in back. YES THEY EASILY MOVE. The weather stripping is part of the glass. Search for a mega rattle post on this website and the guy shows the window removed. As far as the t glass, screw that go back with standard glass of ebay for $300 used.
I would love to see a picture of this separating glass, More than likely another stupid fk advisor milking money.....
QuietFiend (04-11-2023)
Thats originally what I thought too and that the lower bolt behind the b pillar just needed to be tightened down. Even when i washed the car I didnt notice any leaking or strange wind noises, for now it doesn't at least.
I would prefer to stick with the lightweight glass if possible. At this point Im thinking of just taking it to a local indy Porsche shop and just have them remove the bolt and try retightening it down. Just to get a 2nd opinion
