Complete service history?
Will a dealer provide a complete service history on a CPO car? My Macan is due for its interim service but it’s at 64,000 miles so I don’t know if it needs its 60k service or 70K. I had an issue with the dealer I bought it from not doing a service that I think should have been done. My understanding of CPO is that all prior service need to be up to date for them to certify so they should have the information and be able to send to me?
They provided me with a complete history before I bought it. I used that to make sure it was up to date, and even got them to perform additional service that was missing.
There is not a central Porsche service database where all work can be seen, so you are at the whim of individual dealers (if you can figure out which ones did the work).
Some will also pull the privacy card and refuse to share.
manifold danger (01-20-2021)
[QUOTE=spiderv6;17173586]There is not a central Porsche service database where all work can be seen, so you are at the whim of individual dealers (if you can figure out which ones did the work).
I believe this is incorrect, a dealer likely can run your vin and quickly see all warranty work along with what I think includes maintenance as well
[QUOTE=CCDD;17176080]
You would think that, but spiderv6's post was echoed to me almost verbatim when I went to trade in my Boxster for my current 911. I was trying to do a "pass through" trade with another buyer, and was trying to certify the car for the new buyer at the same time so I was directly involved in the process. The dealer I was trading in to made me get service records at two separate past dealers to validate it had a complete service history. I asked the question of why do I need to get the records, can't you see them in some database or something, and was told pretty much what spiderv6 is saying; not all dealers share and if they do it's most likely through Carfax, not a central Porsche repository, and I had to get them myself because some dealers won't share due to privacy.
Not all dealers/sales guys may do this, and I don't know how effective or purposeful this procedure actually is. It may not apply to warranty work but it does apply to maintenance.
My CPO car came with a general printout with high level things like oil change, suspension check, 40k service, etc and the mileage and date it was done. Basically a summary. Nothing too detailed but it listed every service the car had done at their dealer, where the majority of it's servicing was done.
CTDan (01-23-2021)
To put a finer point on my comment - I actually would guess that there IS a centralized databased but that each dealer is locked out to only see the work they have performed.
PCNA I would assume can see everything. Doesn't fundamentally change the original answer.
Pure guesswork, but as a technologist, I can't imagine they would do it any differently.
I thought the reason you need a piwis to reset the oil light was so Porsche could keep track of things like oil changes and CPO history. I guess I was wrong.
