Windshield replaced today. Has this happend to anyone else?
So my windshield was replaced today and they did an excellent job. Ideal Auto Glass if anyone is in central FL and needs a new windshield. Anyway when they pulled off the factory windshield and seals the red pull-off tape was still attached. Has anyone else had this experience? The install tech pointed this out as he was prepping the new OEM windshield for installation and removing the same tape.
That is 3m VHB tape. Double sided tape. It is structural. That could have been catastrophic! Thank goodness you found out this way and not when you really needed the structural support of the windshield. You are a lucky guy today! That is the best way to accept this news.
That is 3m VHB tape. Double sided tape. It is structural. That could have been catastrophic! Thank goodness you found out this way and not when you really needed the structural support of windshield. You are a lucky guy today! That is the best way to accept this news.
Are you the first owner on your car? Any chance a windshield was replaced prior to your ownership without your knowledge? My guess is in the factory they wouldn't have the red tape still attached, ever, I'd think they would have double sided tape with both sides exposed and then apply it to the car as is, eliminating that risk. It seems more likely that at 2k miles even, car got a stone chip, you bought it after and someone when installing the windshield forgot to remove the red tape.
desmotesta (01-18-2021)
I have seen factory tours a production lines and seem to remember that the windshield had a bead of caulk applied to it prior to robot arm installing it.
Send these photos to Porsche. If this is OEM install error they might want to know.
