Fidelity Powertrain warranty
My CPO warranty is coming to an end in May and I decided I do not care to own a PDK car without having some sort of coverage, and not quite ready yet to move into a newer faster model. I am shopping the 3 levels of Fidelity warranty and am wondering if Powertrain is sufficient for my use. I don't need warranty fix my car if water pump or a shock or something like that breaks, just really to cover me if I get that dreaded PDK warning when putting car into reverse.
Anyone know if Fidelity Powertrain would cover all things PDK? Some bore scoring coverage would be nice too? From the description it sounds like it should.
Researched Extended Warranty options a few months ago... Fidelity was the people's choice relative to price, service and customer service.
Have not used it, But it was the best premium of the dealers selling Fidelity. Toyota -FORD dealer in Greenfield Mass. was the best based on previous customers,
*call Troy D.
*call Troy D.
On the 997 forum the common failure has been well-documented and the guesses have been go Platinum. I've not read anywhere on Rennlist about anybody's PDK being covered by either Powertrain for Gold.
That is because there is no clear answer. IIRC, the Fidelity power train warranty specifically excludes electronic components but does protect the mechanical aspect of the transmission. Important because the PDK failure is never mechanical. The seven-speed gear box is excellent and highly reliable. PDK issue is usually failure of an electronic hall effect distance sensor on the shift rods inside the transmission case. See “Repairing the PDK Transmission” sticky by PPV997 which is excellent. Porsche refuses to replace the electronic part and requires a $20k transmission swap instead of just replacing the $300 sensor. So, the assumption is that Fidelity will deny coverage under the power train warranty because the failure is an electronic component rather than the mechanical gear set, but I do not think anyone is absolutely certain. No one wants to be the test case and take the gamble. On the other hand, we have had numerous members with full $20k + PDK replacements and swaps paid for under the Fidelity Platinum policy. Check out recent thread by “Sandwedge”. You can reach out to Fidelity with the above facts and see what they say. If they say in writing they will cover the PDK distance sensor failure with the power train warranty under these facts then post response here. You will be an instant RL hero.
From Fidelity's verbiage it sounds like it SHOULD be covered, as it is a component within the bell housing.
TRANSMISSION/TRANSAXLE/TRANSFER CASE
All internally lubricated parts contained within the transmission, transaxle and transfer case, plus the following: all internal fasteners, nuts and bolts; shift cover and forks; bell housing, components within the bell housing; torque converter; external valve bodies, control units and solenoids; seals and gaskets.
BGLeduc (01-12-2021)
Yes I have read that excellent thread and agree if/when it fails it will likely be that sensor.... It's a tough call because the spread between Powertrain and Platinum is nearly 80%
All internally lubricated parts contained within the transmission, transaxle and transfer case, plus the following: all internal fasteners, nuts and bolts; shift cover and forks; bell housing, components within the bell housing; torque converter; external valve bodies, control units and solenoids; seals and gaskets.Everyone on RL, including me, hopes you are correct. Then we can all get Power Train instead of Platinum warranties and all save some $$$$$$. I am not arguing. I agree. But, I am just explaining the thought process expressed in from previous threads.
All internally lubricated parts contained within the transmission, transaxle and transfer case, plus the following: all internal fasteners, nuts and bolts; shift cover and forks; bell housing, components within the bell housing; torque converter; external valve bodies, control units and solenoids; seals and gaskets.That was the only reason I bought the powertrain warranty and wanted to ensure it was in fact covered.
Feel free to reach out to him yourself to double check if you'd like.
The following 3 users liked this post by SealGrey997:
Not throwing stones here - just curious.
I too will likely get Fidelity as my warranty will expire later this year. Just curious, was there any official documentation from him that the PDK is covered? Based on the OP's research, it seems that way but it is a bit concerning to put trust in a person just saying something. I doubt he'd be held liable, particularly if there was no written proof.
I guess I did take a bit of a chance by taking his word vs. confirming with Fidelity themselves. However, given he's sold 100's of these warranties for Porsche's, I figured it'd be a safe bet.
Cool that's who I am dealing with. I might give my selling and or local dealer to see if they have any Fidelity Powertrain experience. If so the 3/36 Fidelity PT is a great deal IMO.
SealGrey997 (01-12-2021)
