991.2 Online map updates problem
Hi all, I posted this in the GT3RS forum, but nobody there had the answer. Maybe a kind soul here can help?
All the online Porsche Connect services in my 2019 GT3RS work fine, except map updates. The PCM shows me that there are 2020 updates, lets me select my regions, and start the download. And then nothing happens: the little download symbol appears on the PCM footer, but the download reports 0 B/S and stays there. I've tried it using the embedded SIM internet connection, including driving to a strong signal area. I've also turned off the PCM 'phone, which allows me to use my home wifi instead.
I called Porsche Support and they sent me an email suggesting that I hard reset the PCM and do a Vehicle Handover. The problem is that the hard reset procedure is for an older/different PCM, involving holding down the INFO button for 10 seconds. The 991.2 GT3RS doesn't have an INFO button. All my online searches for PCM reset describe the INFO button. I tried holding down various other buttons; nada. I did the Vehicle Handover anyway, with no result.
Any ideas please? Many thanks!
I have the same issue here in Switzerland (with my 991.2 gts). 2 maps are available but will just not d/l and install. Otherwise eveything works fine with the PCM (bar google earth ofc) Connect functions... Read somewhere this is a known issue (at least the google part) and would be sorted by Feb 2021...
Basic Sponsor
Best is not to use online updates.
Oflline safer and better way,and also your license for updates might be expired.
NAR newest maps are 2020/2021.
EU are 2021.
If you want to know more PM me.
EU are 2021.
Frank996 (01-24-2021)
I've had variants of Porsche online services in several cars now, and they've been mostly overcomplicated and/or flaky. The exception is my 2020 Taycan, where everything works like it should, with only one app, and no messing around.
I did not know you could update maps (i.e. as an end user) via the SD option but only via the online service. I have the Porsche connect included until June 2022 so not worried about the update license expiring - just annoyed it’s not working :-)
My Volvo XC60 has lifetime map updates included and can be done either via 4G or d/l via their website and then import/upload through a USB dongle which is much handier than the PCM 4.0 setup...
Going to PM you for more info...
Basic Sponsor
Porsche Connect license is not equal to maps license.
It is limited to 5 free updates or 2-1/2 years.
For example if you car is 2016,you can update to 2018-2019 map package.
And as I see from your signatures,you most likely have free map updates expired.
Not sure, but I think it said 2 x a year free map updates until June 2022... Will need to check...
Basic Sponsor
The Porsche owner web site is very clear that one of the Porsche Connect services is the ability to download online map updates (with a hard-to-discern annual limit). I've used that service successfully with a prior 2019 Panamera Turbo. You check for updates (or the car tells you that updates are available), select the region(s) you want, and a gigabyte or so of data downloads to the car. It just doesn't work on my 2019 GT3RS. The attached photo of the subscriptions screen in the PCM confirms that my update service is current. The system offers me 2020/21 updates, I select them, it asks me to start the download, and that's where everything stops..
My Taycan has downloaded several updates automatically in the 9 months that I've owned it. It's a very different version of PCM, though.
And, in any case, a 2019 GT3RS should have access to 2020/2021 maps.
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/1_6b4d9feacb3dcc223ed92267d735d6b245d8e9f2.jpeg)
Basic Sponsor
PCM5 and PCM4 can't be compared.
If you wish,I can send you latest offline package to try it.
Full maps are 13gb's so need atleast 16gb sd card.
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/3_b815ac14da363fc24d1fb237a42bb6c3f50be069.jpeg)
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/0_8f4b85249528490b8bf3134f5df07d876ee2b190.jpeg)
My car (991.2 T) won’t pull OTA map updates at all. I’m running 2018/2019 maps and when I check it says no update found. I have Connect subscribed til 11/2021 and the other “features” (News, weather, traffic) work just fine.
is there a way to download the map files via computer? I have plenty of SD cards/flash drives with capacity.
also....does it really try to download 10+ GB over LTE? I feel like that would take a week to download
Basic Sponsor
No,they update just the region you are in right now.
OTA never updates full maps.
So thats why offline update is the real deal.
If you have map license,you can use 2021 maps.
If not they will just fail to install.
License can be extended of course.
