PCM Clock is slow
I took my 2015 C2S in for service last week, since then then time that shows up on the PCM is 15 minutes slow. It was incorrect on the gauges as well but I corrected that, however it's still showing slow on teh PCM. I held down he Info button to reset the PCM but it did not correct the problem. Any other suggestions?
Received 5,413 Likes
Don't forget E equals m c squared. So, as you are approaching the speed of light, easy to do in a 991, you are compressing time. And that causes your clock to run slow.
I had the same thing happen. When I took it in for service, I mentioned it and it was correct when I picked it up. But I don't know what they did to correct it.
True. Technically the faster you drive the longer you will live. From the perspective of those you leave at home.
