Clock/GPS time daylight savings time
Noticed today the clock was behind 1 hr, even though it is set to auto gps time and in the correct time. It did not adjust for daylight savings and I didn’t find a setting for daylight savings.
also the gps clock did not match my cell phone, was off by a minute or so.
is this normal? Meaning no adjustment for daylight savings
i set it manually for now
Received 3,460 Likes
Mine adjusted automatically.
Hummm... I'm seeing screen shots that must be in the newer cars.
My 2013 is all manual for time/date select.
I don't have the summar time option
I always had Auto sync/ GPS time checked
Today I unchecked and checked a few times and it synched correctly. Must be another Porsche qwerk
Just had this happen in my car. Time was all kinds of wrong after a battery disconnect during winter storage. Set it to auto and it came up with the correct time/date except one hour off. Unchecked "auto" as I was going to just manually set it and, for some reason, then decided to check auto again and it immediately changed the time to the current/correct time. Mine's a 2019 fwiw and this seems to be different behavior from my Macan.
991.1 user here. I have to go in manually at every DST swap and uncheck or check "DST" even with GPS Time checked.
