Advice wanted on purchasing a 2017 Carrera base
I am looking to purchase a 2017 Carrera 911 (base) model. I would obviously get a PPI prior to purchasing it but I still feel like I do not know what to look for. The price for this vehicle is $74,000 with 18,000 miles and it has a factory warranty through mid-November. The base MSRP was $106K. The car appears flawless and it has a clean carfax. I know the PPI will really tell the story of the condition of the vehicle but how can I tell if I am getting a good deal? Given the chance to purchase an extended warranty, is that something I should purchase from the dealership? I see myself keeping this vehicle for a long long time. I do not see myself tracking it and now that I work from home, it will literally be my daily driver and I would likely put under 4000 miles per year, potentially a lot less than that. Any advice for how to look at this deal? Thank you.
You can shop extended warranties from 3rd party companies like fidelity.
If the car is not CPO from the dealer you can ask them why.
you can ask the dealership for maintenance records on the car and warranty work done on it.
2017 was the first year of the 3.0 turbo motor and there are a few known issues with it.
you should use the search.
Make sure the car has the options you find most important. Upgrading the lights OEM LED, for example or trying to add sports chrono launch control is damn near impossible or costly.
you should not rush to buy it if you are not ready and educated about this purchase.
good luck.
good luck.
dallasporsche911 (11-03-2020)
Find out where the car has been serviced. Hopefully it was at Porsche. If so, give the service advisor the vin# and should be able to find out all the complaints the previous owner may have had.
Hard to say if the price is good / bad without a list of options, condition, etc. Car is being sold with a month left on the warranty. Why? If it's the black car linked, it is being sold after being owned by second owner for 5 months. Why? 18K miles, how are the tires? Budget $1.6K-18K, maybe, for a set of Michelins. Check brakes front and rear for rotor dishing; easy DIY for both pads and rotors, or it's an arm+leg deal at the dealer.
Is the 20K/two-year service due? That's an oil change and brake fluid, couple filters (cabin and frunk, easy peasy DIY+parts), IIRC. Pretty straightforward stuff. There are not a huge amount of problems on these cars on the forums, from what I've seen. I guess one is the Water Pump leaking; generally fixed under warranty. Definitely something to look for under the rear of the car after an overnight sit. If you see coolant, def get it to the dealer while it is under warranty (the water pump may have been replaced already; hence getting the service records.) There are some threads on the door panel separating; be good to look for that also.
I bought my CPO '17 as the second owner last June with 18K, now 27K, no major issues, it's been fun and reliable. I really enjoy it.
Good luck!
Good luck!
The following 2 users liked this post by Rich_Jenkins:
dallasporsche911 (11-03-2020),
I am the Walrus (11-03-2020)
Good luck!
Good luck!
The ins and outs are no different from any other car.
Parts are reasonably priced and widely available, and dealerships tend to gouge on routine service charges.
A good Indy shop is the way to go and as long as you maintain the car, you'll be fine.
You can also do a lot of the maintenance yourself (if you are technically inclined) as it's an extremely easy engine to work on.
The water pumps are known to have issues on early 991.2 (which is well documented), but no other known issues.
Lastly, people flip these cars at an alarming rate for a variety of reasons (Off lease, boredom, life changes, new-toy syndrome, etc), so # of owners shouldn't necessarily be a red flag.
You'll find far more real-world information on this forum than from any salesman or service advisor, both of whom are known to trawl these boards.
Rich_Jenkins (11-03-2020)
Jut my $.02: The black Coupe listed in AutoTrader appears to have all the comfort options (Bose sound, 18-way, heated and cooled seats, glass sunroof, LED head lights) but light on performance options (sport Chrono, sport exhaust, PASM, 4 wheel steering... ). Whether that is good depends entirely upon you. The base Coupe has all the performance you likely need. Adding options you wish the car had is expensive. I'm guessing that because it's not a performance-oriented spec, it's not been abused. Very hard to hide imperfections on a black car. I doubt you really need an extended warranty when you will be putting few miles on the car. Whether the price is good will depend on your negotiating ability and what's available in your area.
I would pass on this car personally based on the fact that the wheels have been painted/coated. I'm not a fan of the tinted windows either...
Whoever the original owner was, it doesn't look like they took the greatest care of the interior....
https://www.platinumautohaus.com/201...ra-c-13493.htm
Anybody else want to throw their $.02 in as well (I am not being sarcastic)? I am actually less inclined on the performance parts and more on the comfort. That said, I would like to mod the exhaust note so I would appreciate anyone's input on how feasible that is on the base model. Not to be lazy (ironically I am a productivity coach) but I just don't know the ins and outs of what to look for but what suggestions would anyone have for doing due diligence other than a PPI? Does anything look suspicious on the Carfax? With 2 weeks remaining on the warranty, is it worth rushing to get an extended warranty from Porsche? Owner appears firm on $74,000.
For diligence, these cars are new enough that I would simply check Carfax, have a report on the engine computer to check for over-revs (!), and then take the car to a body shop (not the dealer's) to have it looked over for paint thickness and/or accident repairs. I wouldn't, however, move slowly. 991.2 Carreras with manual gearboxes are rare things. If you can have the person who has put the miles take you out for a ride (so you can see how they shift the thing, and treat a cold engine), all the better.
ngamountains (11-03-2020)
To OP
regarding exhaust mods, since turbocharged, not really required. If you want more sound, change the cats with sport cats from SOUL. A very good product
also, buying a base car is not bad per Stout above. Lower cost Leaves extra budget if you want to add other mods such as tuning, etc.
with simple tune from APR, softronic, VF engineering, Cobb etc you can easily get close to 500hp on this model with 91/93 fuel.
Good luck in your quest.
