Installing winter wheels with no TPMS?
I just bought black Carrera S wheels for my 991.1 and Michelin Alpin tires to use as my winter wheels/tires. If I get these wheels installed without a TPMS sensors, other than an error code showing up on my dash will there be any issues (using any features on m dash, warning beeps etc.).
I don't care about being able to see my tire pressure on my dash so I'd rather not spend money on sensor for my winter wheels.
http://www.ebay.com/itm/303509108192
Yes, after awhile you may also get suspension warning. See owners manual.
You will have a constant warning light, annoying. Not worth it.
I think it's just the error code but why not install the tpms? You can get them for $80 on ebay.
Also, please remember that TPMS will alert you to a change in tire pressure and possible flat. You drive a (give or take) $100K car and want to save a few hundred bucks by not having this safety information feature???
SConn (10-26-2020)
With low profile tires I would always use TPMS. I drove off with a flat and the tire was ruined within about 700 feet due to the rim rubbing on the inner sidewall.
https://www.tpmsbargains.com/PORSCHE...PMS-s/1830.htm
Those are cheap Chinese made sensors. Anything that cheap is going to be junk. For your car you will need Rde048 the OE or the same sensor made by the same company is the RDE011. They are Huf which is the same manufacturer of the OE sensors.
