Does anyone not like sport and sport plus modes?
I came from a 991.1 3.4 then a 991.2 cs pdk and now 991.2 cs manual. Especially in the manual car, I feel that in normal mode, PSM sport model, auto start-stop off is the best option. With a manual setup the sport and sport+ is less pronounced but how the clutch/throttle feels is a major drawback. Seems like the computer is keeping the throttle/psi up but when I go to shift and press the clutch there is a delay for the RPMs to drop.
Anyone feel the same?
I prefer throttle response in sport and sport +, I drive a manual 991.2 911T.
I don’t really care all that much for the pops in sport. The overall throttle intake sound in sport plus is more pleasing specifically on deceleration.
spyderbret (10-22-2020)
Sport mode all day everyday. I have a C2, and have never heard a burble or a pop, oddly enough.
Yeah.. I wish I could have the nice, granular sport+ throttle without leaving the turbo spooled all the time. And the sport PDK shifts. And the non-sport PSE open valves.
If only you could mix and match these aspects in individual mode, like you can on a mk7.5 golf R...
90% of the time, its Sport+ in my manual 4S w/X51
No pops
No auto off
PSE is on
Much more alive
No pops
No auto off
PSE is on
Much more alive
I'd drive sport+ all the time if it meant it wouldn't keep the charge pipes pressurized at neutral throttle or deceleration. Either the gauge is lying, or there's constant load on the turbos -- the latter scares me.
TimboCarrera (10-22-2020)
You are right, there is a constant pressurization in S+, I just never thought of the potential premature wear.
Amazing there isn't an aftermarket solution to dial in a true "Individual" mode yet. (Apart from a full tune anyways)
https://en.wikipedia.org/wiki/Low-speed_pre-ignition
Given that the PDK automatically puts you into the lowest (or second lowest) gear it can when you're in S+ leads me to believe that it's not intended for use driving to grocery store.
Rolling around in Sport+ does make the best sounds, however aside from the turbo spooling pros/cons, I would be more concerned about the tendency of the rear end to step out a bit more than expected for around the town/back roads driving.
Wear aside, it gives me anxiety over increased risk of LSPI.
I am no expert, but true boost under load, (75-100% throttle) @ 1500 RPM isnt the same as keeping turbos spooled in neutral. And if so, its at most 1-2 PSI not the full beans. I really wouldnt worry about this at all.
GT3FZS (10-23-2020)
