Overheating
Overheating
Today while driving my 991.2 the car overheated. It got up to 250 degrees and instructed me to pull over. I was about 3 miles away from home when this occurred and had to pull over 5 times to get it home. The car has about 17k miles and I hadn't driven it in almost a week. Has anyone experienced this, or knows possible causes? thanks
Received 5,413 Likes
Failing water pump or Change Over Valve.
dj997 (10-17-2020)
You got the car home? After the temp cools down to 140F you can unscrew the coolant cap and check the coolant level.
You can peak under the car and see if you have any crusty coolant or active coolant leaks.
Please report back.
Please report back.
dj997 (10-17-2020)
Thank you both, I did get the car home but will not be able to tend to it until Monday as I am headed out of town as I type. When I get back I will check and report back. Again, thank you both.
Basic Sponsor
Sounds likely that the water pump is failing and leaking coolant, seems to be slightly a common occurrence on a subset of 991.2's. My 997.2 was low on coolant and I believe the computer automatically "overheats" the gauge and instructs you to pull over to save the engine.
dj997 (10-21-2020)
Received 3,460 Likes
True, especially the 2017s, and some early 2018s...several threads in this forum about the problems.
dj997 (10-21-2020)
I am getting the car towed today, the service adviser suggested it may be the water pump too. They won't be able to actually work on the car until the 30th, but I will keep you updated. Thank you all for the replies.
Pavegeno928 (10-19-2020)
could be the back side of radiators are full of leaves.
dj997 (10-21-2020)
Hello gentlemen, it was indeed the water pump. Thank you all for the input!
dj997 (10-21-2020)
i heard the same BS, rented a car and cost me over $300, all the rentals at enterprise are smokers cars,,,gag me..i checked my coolant the day after picking up and had to add 2 cups coolant,,now it reads perfect
dj997 (10-22-2020)
Yes, I am not a fan of niello, thats why I take my business to SoCal. Fortunately I have a great relationship with a person down south. For service you are kind of stuck though.
