Like these allot.
Anyway to put a custom logo on it? Something to the tune of Porsche by Numeric
Also, sent you a message through your site regarding a spacer for clutch cover. Possible to make one?
Like these allot.
- i quite like the contrasting aluminum.
- i took the gas pedal assembly out of the car to assemble. i imagine it is tons easier this way.
- the hidden bolts are a pain in the *** but worth it for a clean look. i think if i had to do it again i’d consider putting a mirror behind the pedals.
Biased brain says throttle response is a tad better...the pedal angle is slightly forward, or as I say it could be the beer.
IPA from our local micro (Institution Ale) always makes mods better....when they give you a bit of a problem, just pop another and it seems all
is well!
Love the aluminum finish look. I'm definitely leaning towards that.
I did my installation last week. It was fairly smooth though:
- the brake pedal was a tighter fit than the clutch. It looks like the brake is slightly larger in shape.
- It was pretty hard to slide the gas pedal in (the bottom part). I had to use a hammer.
