Numeric Shifter Cables worth it?
While I have no actual experiences with numeric, from what I have read the answer is a big yes.
I put the Numeric cables on my 2011 987.2 Cayman S and the difference was dramatic. Much more precise, no slop. And peace of mind knowing the ends aren't going to break and leave you stranded. Worth every penny.
Had them on my 997 and the shifter and cables transformed the whole stick experience. Just the shifter was an improvement but the cables brought it all together. Just a FYI...the cables do transfer a little of gear noise into the cabin but it is not intrusive or annoying, but at least for me, ties you more to the car (if that makes sense). If you’re thinking of a Function First Trans Mount bushing to stiffen up the movement of the trans, that really increases the NVH into the cabin. I did and took it out a week later.
I have the Function First Trans mount in Orange (Softest) It does transmit some NVH, but it noticeably improves the throttle response and shifter feel. To me it's worth it. I would not get anything harder than their softest one.
I also have the numeric shifter and love it. I was going to get their cables until I saw this.
https://www.ebay.com/itm/Precision-W...72.m2749.l2649
And then saw reviews from the 997 guys here and figured I would take one for the team
https://rennlist.com/forums/997-foru...es-review.html
Did the shifter and cables on my Carrera T. Don't know what the extra increment due to cables is but, overall, VERY HAPPY. Cables did seem a bit stouter than stock. Would also recommend safety wiring them in at the transmission end. Bonus is that if you do the install yourself (not too tough) you get TWO punches on your "Carperson" card.
Is there a video somewhere showing how to install the cables? The only one I could find was in a cup car that didn’t have the armrest or interior trim.
I installed the Numeric shifter and cables in my T. I initially had a fair bit of mechanical noise in the cabin until installing the silicone tubing on the exterior sections. Much quieter now. Overall, super pleased and highly recommend for those looking for a more precise and easier shifting experience.
I put the numeric shifter and cables in my '18 4GTS. I echo all the comments about how much improved it is over stock. I did have a lot of noise coming into the cabin from the cables though. They made a lot of noise at a certain RPM. I read another thread about this on here. I decided to wrap coolant hose around the cables and put sound deadening material under neath the center console where the shifter and cables are located. Since you're going to be in this area, I highly recommend doing this.
