My single post lift keeps getting delayed because of the Wuhan Flu:/. But everything else is coming along. The 987 was living outside until this weekend during the Reno since the garage was storing appliances and supplies. I finally got the garage back, floor installed and 911 detailed. Still have some cleaning up to do to get everything dialing in but thought I’d share a few pictures.
looks nice but what happen s when you drop that small screw??
Small screws won't fit through the gaps unless they are VERY small in which case I'll be using a bench. I also save large cardboard from things that I use for projects
I was laid off around the time I was shopping but will be going with an ACL single post once the Reno is done and I'm working again. For a 2 car garage they just make the most sense and use the least amount of footprint.
Interesting door at the end of your garage - just how tall are you anyway?
DaveGee
It's a regular size door. This is just a sad reality check that 911's have gotten so big!
(its the crawlspace entrance which is awesome because when I open it and set a fan in front I have geothermal [FREE] A/C in the garage. It's getting encapsulated soon which will help even more.)
ROTFL!! Only because I had the same thought. I'm so used to attached garages, I just assumed that was the doorway to the house!
Ha! This is attached. The door is to the right and I still have a lot of trimming to do around the couple of stairs and that side so I just framed the picture to look nicer.
