why would a car have spark plugs replaced twice well before 40k miles per the Carfax?
I'd really be interested in peoples' perspectives on why a car would have spark plugs replaced twice about a year apart according to the Carfax. Below are the service summaries from the Carfax, and the link to the full Carfax is at the bottom. I'm going to ask the selling dealer (and hope to get a response from the servicing dealer), but any thoughts from you guys on what this could mean would be appreciated.
9/13/2018:
9/20/2019:
Full Carfax: https://www.carfax.com/VehicleHistor...BB2A92HS136755
9/13/2018:
- Maintenance inspection completed
- Recommended maintenance performed
- Safety inspection performed
- Battery/charging system checked
- Spark plug(s) replaced - (why would this be needed with less than 4k miles on the car?)
- Air filter replaced
- Brakes checked
- Oil and filter changed
- Tire condition and pressure checked
- Electrical system checked
9/20/2019:
- Spark plug(s) replaced (why would this be needed AGAIN around the 7k mile mark?)
- Brakes checked
- Brake fluid checked
The previous owner was a nut.
People believe all sorts of things, and if you say replace the plugs, a service department would do it.....
The air filters were also changed twice before their time was due. But the brake fluid was not changed when due. It would not surprise me if the info was merely reported carelessly (inaccurately). by the Porsche dealer. Regardless, I wouldn't worry about it. But you should get the brake fluid changed.
If you can actually get all of the service records then you might get the full story. You will likely be told the customer was OCD. Maybe...or maybe there was something more significant going on and this was part of the resolution. Possibly more major fuel pump issue? I believe someone on RL was told to change the plug after a HPFP failure and subsequent replacement.
i had a VW Touareg bought back by VW after an engine failure that resulted in oil getting into the coolant system. This was at about 900 miles on the odometer. In the end they replaced the V8 and I drove it till about 2500 miles. Car was going to be sold at an out of state auction, I was told. So what will the buyer of my rebuilt Touareg be told? The guy was a car flipper. He bought a new car every 9 months.
Ask questions answered make sure you are comfortable with the decision to buy if you decide to. And the risk that comes along with it. Good luck.
possible misfires or coil bad coil packs.. dealers and techs LOVE to throw parts at car especially when its under warranty
secondly, extremely **** owners could change spark plugs by age and not mileage.. who knows.. I dont see it as a red flag if a DME report comes back clean
call that dealer and ask for more details about the repairs.. if they pushback, have the seller make the call and demand more details..
good luck
good luck
How sure are we that the Carfax is accurate?
Received 1,679 Likes
If both “plug changes” were done at the same dealer then I would question if either was done since that dealer is clearly not worried about ‘getting caught.’ If at different dealers, then probably done at least once.
This ——^ about the brake fluid.
I have seen Porsche Dealer records where the charged-for services were clearly not done. I have also seen Porsche Dealer records where the same parts were charged for twice on the same invoice. (Seriously.)
Mine were done at 5k miles on the 4 year service schedule to cpo. My guess is the second time was due to a crooked service advisor. I called Jax porsche on my 6 year which called for a new pdcc bottle and the guy suggested i needed a water pump with the sevice due to failures. His total would have been 5k for the 6 year service. By the way early .1s dont have water pump failures.
An independent PPI or service history will show any codes thrown. If it did need spark plugs my guess is there will be a history of the code in the service records.
I evaluated a car that showed all service accomplished prior to the perspective purchaser's interest. The original owner however had specified an oil of a type/quality the latest purchaser didn't wish to use so had the dealer dump oil within 50 miles of the previous major and reservice. If it caught my eye I'm sure it'll catch the "eagle eye" of someone researching to become this automobile's next steward.
Anecdotal I realize, but provides some food for thought...
CarFax credibilty is suspect these days, IMO. Dealers are not making it available so do they hide important information? YES!
Ask questions,
In the last few months of searching for the ideal 911 CarFax has come up with many inconsistencies. These are a few...
-extra plug replacement, well before 40k or 4yrs, why?
-repainted door not reported on CPO $100k+ on 911
-full 20k and 30k service within the same year (~3k miles apart)
-repainted bumper, not fitted properly, not reported CPO 911
-missing brake flush - dealers fault quite a few or not reported
-found accident listed as damage but it was a $20k +/- repair, CrFx/dealer reported with no details
PPI at dealer not data-base listed after 19 days!
Porsche costumers follow Reps advice but it cost money and its a waste
Ask questions,
