Seat 911 stitching snagged
I recommend growing your hair longer. ;-)
Received 4,351 Likes
A dealer can't fix that, it would be replaced. It was snagged, not defective.
Trim the strings off with cuticle scissors leave just a small bit hanging, don't go totally flush. Maybe 1/16 of an inch. Take a very small dab of Superglue Gel on a toothpick and glue down the existing end thread. Will be a permanent fix and you won't see it. Not too much glue, just a very small amount.
Upholstery
Resident seamstress says she would try attaching small curved needle to hanging thread and going through holes in leather, to mend pulled out area. Since original stitching goes back and forth, with a separate thread underneath to catch the white thread, you’ll need to be careful not to pull more out. Suggest a hemostat to stabilize thread where it last came out, so that when you remove slack (while re-stitching), that more does not come out.
We believe an upholstery shop could easily do, if you can’t yourself.
Cheers
Cheers
Received 3,460 Likes
Cheers
Cheers
What do you think about removing all the stitching? You might be left with a shadow and some small needle pinholes, which may disappear over time. Leaving bald spots would bother me.
If you find the best upholstery shop in your region, they should be able to salvage this mess. Maybe call eExclusive option since they claim to have leather and thread that matches the factory choices.
