Rear seat luggage/dog carrying modification
Ok, this is awesome Icebreaker! I'm thinking I'll definitely want to do something like this. Our pup was uncomfortable on the folded down seats as she's pretty lanky and just couldn't get comfortable/was compelled to "fall" into the gap behind the seats. She does much better just sitting in the buckets but I know that can't be the most comfortable thing either. She really likes the headroom, though, so I might try a cheap version of this just to see how comfy she ends up being.
I've been considering making my own seat cover as well. We have an Orvis "hammock" style cover for our X5, but there really isn't anything that's made that's practical for the rear seat of the 911 (the Orvis covers come in L and XL, lol).
This system isn't complicated and only took minutes for the foam store to cut and glue for me. Have fun and send pictures of your dogs in the car. Nellie (see above post by Pavegeno928) looks so peaceful. RIP Nellie.
Thanks for the tip! I'm going to head to a local foam supplier in the next month or so. I also have an idea for a sort of "curtain" to protect the seat backs and plastic side panels - thinking that it could hang from the coat hangers on the seat backs and maybe stick to the quarter windows with a suction cup (since I'm guessing there's no space to shove a tab down in between the glass/trim). Could use mesh between the seats to allow the pup to still see out the front (similar to this).
Here in the Bay Area I found Bob's Custom Foam shop in Fremont. Once I explained what I was looking for they custom cut 4 pieces of a very stiff foam for me in about an hour. Total cost out the door was $131.00. Together the 4 pieces form a flat deck that is held in place by friction and the front seats. Went to Costco and bought a nicely padded rear seat dog cover. It's to large for the Porsche which is perfect as it allows the sides and rear to fold up along the rear side walls and cover the rear floor area as well. I toped it off with a Costco dog bed that is a perfect snug fit for the back of the Porsche.
As you can see from the pictures, she is sitting up high enough for 360 degree views of the world and since the dog bed is held tightly in place she has plenty of grip not to get thrown around in corners. It kind of funny to watch, on the straights or just cruising she likes to stand and get a view out the front, corners start to happen she just sits down on her butt, more aggressive cornering she just lies down and enjoys the ride. We are planning on a puppy this spring so both will fit nicely in back.
Wrtflyr (01-08-2021)
Great idea to add the bed for side protection! She looks comfortable! Did the foam supplier glue any of the pieces together for you? Enjoy! (both you and your pup)
Nicely done! Any photos of the foam pieces?
They look pretty much the same as the ones Icebreaker posted. If you find a custom foam shop they start with a block of foam and start cutting for the basic dimensions and then start shaving for a final fit. The foam does not have to be a prefect fit ,as I and most people will throw some type of cover over the entire back deck which covers the foam and provides protection to the foam and side surfaces from a dogs paws & claws. This is a simple project. Don't over think it.
Ice been looking for a week now!! Thank you so much for Idea. I have leftover acoustic foam from Home theater should do the trick then place maybe a top to large container top to cover them & carpet.
Thanks!
Hey OP,
Thanks so much for sharing this! I've been looking for something that would enable me to bring our Australian Shepherd (60 pounds-ish) with us in our new to us 991.1.
This was just what we needed - getting the supplies next week and getting it glued together.
Do you by any chance remember what Newton og lbs the foam you got was rated at?
Thanks again! :-)
Thanks again! :-)
How much egress / ingress would you have with the bucket seat slid all the way forward? I'm assuming for this kind of dog in the back setup a 4 way or 18 way seat would be much wiser.
I normally lift her in just to make sure she doesn't dig her claws in where I would later regret. Another approach that someone else uses is to place a towel on the front seat and then let the dog climb into the master suite.
Glad we have a good solution for carrying our best friends around safely! Cheers!
UncleDude (02-01-2022)
With the seat forward, our 55lb dog can get in pretty easily. The first picture in the thread shows the room available with the seat forward and the foam insert.
Rear seat I
My 1988 911 Cab had lots of space for my cross-country drive in 2011. Packed the footwells with soft bags right up to the seats and put a blanket down. Sadly, Nellie passed a few years later, but the Cab is still with me.
my dog looks kinda similar!
