Twitchy Throttle
Old May 29, 2020 | 10:38 AM
rockrdude's Avatar
rockrdude
Default Twitchy Throttle
Hey guys,
Since My last refuel I have been experiencing a bit of a twitchy throttle response at low speed. Which is odd because this is something I actually loved about the car how it was smooth at low speed yet ripped if you gave it the beans. The last refuel was 94 octane at a local gas station (petro canada), could it be a batch of bad fuel? the car has 6000km with no performance mods. Just checking if anyone has had a similar experience here.
could it be:
bad fuel batch?
car finally opened up after 6k km?
PDK issue?
fuel pump?
throttle sensor?
am I simply going crazy from 3 months of confinement and overthinking everything?
Old May 29, 2020 | 10:41 AM
LexVan's Avatar
LexVan
My guess would be bad fuel. Not many people driving, and the last fill-up you received may have been a bit stale. Keep toping up every 1/4 tank.
Old May 29, 2020 | 10:45 AM
rockrdude's Avatar
rockrdude
yes that was my first thought, I'll top it off at a diff gas station today, see if it helps.
Old May 29, 2020 | 12:34 PM
duxsi's Avatar
duxsi
Out of interest, how quickly does fuel degrade / go stale in a gas station environment?
Old May 29, 2020 | 01:59 PM
Carlo_Carrera's Avatar
Carlo_Carrera
Modern fuels absorb water when they sit around. Much more so than in the past. That is what does it.
Old May 29, 2020 | 05:11 PM
whiteducktail's Avatar
whiteducktail
You're right. Ethanol in fuel absorbs moisture to form an azeotrope with water.
Old May 29, 2020 | 05:15 PM
barncobob's Avatar
barncobob
put some Techron strong dose in it and give it an EYEtalian tuneup,,,drive the poop out of it....old school but it always works..
Old May 29, 2020 | 05:53 PM
koala's Avatar
koala
Try to use fuel without ethanol in it. In Canada, Shell 91 or Chevron 94 are both good choices!
Old May 29, 2020 | 06:04 PM
rockrdude's Avatar
rockrdude
Topped off the tank 1/2 with esso 91. After driving around a bit it feels slightly better, so that might be the culprit. Petro can 94 must have a lot more ethanol right? I’ll top it off again in a few days at the shell close to my house and prioritize that station from now on.
thanks for the replies everybody
Old May 29, 2020 | 06:48 PM
koala's Avatar
koala
Esso 91 and Petro 94 both have "up to 10%" ethanol. It's absolutely anecdotal, but I find my 991 runs so much better without any ethanol. I found Petro 94 to be worse, in a way, as the higher octane is also developing a little bit more power than you would on 91, so it was making the these twitchy feelings more noticeable, IMO.
Old May 29, 2020 | 07:31 PM
barncobob's Avatar
barncobob
UR all from Canada,,guessing gas supply is the culprit..
Old May 29, 2020 | 08:26 PM
rockrdude's Avatar
rockrdude
So what's gonna happen if they enforce 15% ethanol like they plan to do in Quebec? we'll all have twitchy cars? 🤣
