Rear fuse panel?
Subscribe
Apr 23, 2022 | 09:44 AM
Quote: Maybe I can change the question a bit... I have a 991.1 GT3. I have a DSC suspension controller. At the end of a recent track weekend I got a PASM suspension fault. I re-installed the factory controller and the issue remained. I took it to the dealer and the issue was a "5 amp fuse in the rear fuse box was blown and replaced". I spoke with DSC and they said they have never seen this before. So I was hoping to replace the fuse myself if it ever happens again. The fuse probably took a few minutes to replace, but having the dealer figure out that it was a fuse and replacing the "right" fuse was quite expensive! So if anyone knows which fuse it is that would really help. Otherwise I can look at each one individually if it happens again.
Thanks for all the replies.
I would suggest testing the entire fusebox with a multimeter, it would not hurt… besides you are counting on that the dealer diagnosis was correct.
Reply 0
Subscribe
