Bridgestone Potenza RE980AS
A new set of these tires were mounted on factory 20 inch wheels and installed on my 2012.5 C2 last month after alignment. My car was delivered with PZero tires in June 2012 and they were replaced with a set of Michelin PSS.
I am grateful to the dealer who talked me into purchasing a 5 year tire and wheel policy,then only about $1300 as the Pirelli and Michelin tires effectively removed every bit of road debris they encountered - the warranty provider bought more tires than I can recall, replaced a wheel and fixed a few others. Winters tires (factory Pirelli Sottozero II) on 19 inch wheel were used every year without any problems and they have now aged out even though they still have tread.
I wanted an all season set to avoid the rush to the dealer to swap tires and to allow me to use my daily driver in all temperatures - I avoid snow and not because I do not believe that the car is not capable, but I fear the 4 wheel bandits around here who do not understand the concept of coefficient of friction on ice.
I have noticed that the new tires seem what I can only describe as more stable or firmly planted than the Pirelli or Michelin tires. Almost as if they are heavier.
The also seem to require a lot of "wake up" time to heat up before they provide their best performance. The mileage appears to be lower but the smoothness of ride, noise (my Michelin tires were horribly noisy), tracking (which may be a function of the new alignment), grip, low temperature performance before and after heat up is very good, fatigue factor (my own term for lack of twitchy performance) is low. The tires seem to not over or understeer and hard left and right turns at speed are compliant. I do not track my car and if I did I would probably get separate wheels and dedicated racing tires.
Overall, I am pleased with these tires that cost $905 before a $70 rebate at tire rack
subwoofer (05-03-2020)
Very nice summary and thanks for the recommendation. I am thinking of them as well as my rears (Michelins) are down to 4-5/32nds. BTW, the tires are heavier by 4-6 lbs according to the specs on TR's website.
I'm planning to give these a try when my rear Pirelli's wear out. The main appeals for me would be potentially adding a month or two to my driving season, along with less tire noise. I'm fearful, though, that they'll negatively impact the steering feel/weight, but from your review, that appears to not be an issue?
If and when I ever get back into going to the track, I'd probably be more inclined to use my Golf R for that purpose. Both cars are way beyond my driving ability anyway.
OP I love this line...’I avoid snow and not because I do not believe that the car is not capable, but I fear the 4 wheel bandits around here who do not understand the concept of coefficient of friction on ice.’ 😊
Also I have the Bridgestones and I am very pleased with them.
rnl (05-03-2020)
I hope you know there is an identical thread with over 250 replies about this tire. Good reading. https://rennlist.com/forums/991/1103...a-re980as.html
It is dawning on me that these tires make a lot of sense, even if the purists hate them. First, the stock Pirellis are downright dangerous below 40F, and particularly when it is damp. Second, for street use, how much performance is really needed? Lastly, maybe I will get a chance to use my heated seats and steering wheel. I hate not using the car during cold weather, and buying a winter set is not on my shopping list. Probably about one more season for the rears on my Carrera, then will go to the Bridgestone AS.
T3X4S (05-03-2020)
Could the heavier tire account for a more "planted" feel, less noise and vibration?
My point on performance is that on the street, the AS should have plenty of stick. Your MPSS are likely pretty rigid, but as tires wear, the ride and noise does tend to deteriorate. Perhaps the renewed tread the rebalanced tires and wheels have restored your ride quality.
rnl (05-04-2020)
