Diy plug and play harness for center light bar on 991.2
Good afternoon team,
A couple people asked my about the wiring to install the center light bar for cars that did not come with it. On my car, I installed a 991.2 gts rear bumper with light bar onto my 991.2 carerra t. Here is how it came out
Widebody bumper on narrow body
Cyclopes
Love the look at night!
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/ae0b2d2a_4d83_44f3_85f2_111ffa4a79f8_5a45c3494264243ccdd12d06cbc829dceb7a610f.jpeg)
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/de23f91e_99ee_41c4_ba7c_1118f63d7261_a70eff24fb8421688f0a4fcd1924ae8240280b1e.jpeg)
Cyclopes
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/924a8c46_745e_4098_b3b7_ddba4faf33c8_786e599a5a94f9fd33db5ddef979ba84b821ef1e.jpeg)
Omega4 (04-26-2020)
I purchased the connectors off of deytrade:
https://www.automotive-connectors.com/?___store=english
I purchased three connectors with pigtails to make a plug and play harness. Basically it installs in line with one of the license plate lamps. Here are the connectors I purchased
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/f08cd8f3_0a96_420c_9147_bdece7b2da75_4f4f6e0f16b5b32b4a245b3ae6c6eb575203467d.jpeg)
For the three prong connector, the two outer wires are 12v+ and the center wire is ground. On the license plate plug from the car, the brown wire is ground and the other wire is 12v+. Connect the 12v+ wires together (I used heat shrink connectors that have solder built in)
Same for the ground.
Harness made up. Ground is the top wire and 12v+ is the bottom wire.
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/89c562e2_38a6_4ff7_954b_fd5d7aef39e2_7bcb871313d332a61d1b31bfbc08c665cdeef393.jpeg)
OCNYPORSCHE (04-25-2020)
Awesome, looks great
Is the bumper available for us non-pse folks? Or would this be PSE only?
LargePuppy (04-25-2020)
Thanks, it’s my pleasure, I have the modding bug like so many and am blessed with the ability to turn wrenches. My hope is I can show some others how simple and gratifying some of this stuff is when you can diy. @LargePuppy you are a great asset to the community as well-anxiously awaiting the results of your soul headers to see if I can join that camp when they are available.
To save some time, here are the links of 3 connectors polobai mentioned above:
https://www.automotive-connectors.co...i-neutral.html
https://www.automotive-connectors.co...l-version.html
Thanks for sharing your DIY with fellow members!
polobai (04-25-2020)
Had I known this before comitting to my 4s, outcome might have been different. However everything happens for a reason. Well done!
I second that! And you too, LargePuppy. Your posts have opened many new doors to mods and diy maintenance.
It’s a zero sum gain as I’m spending the money on mods that I would normally be spending on professional labor costs...I’ll gladly take it!
thank you all!
thank you all!
polobai (04-26-2020)
2 addition links I found!
Rear bumper removal DIY:
https://rennlist.com/forums/991/9295...all-gts-2.html
Middle light part #: Reflector Panel - Porsche (991-631-465-02)
https://www.getporscheparts.com/oem-...MtMGwtaDYtZ2Fz
