Taking Long to Crank up
Received 5,410 Likes
All good suggestions:
Battery
Plugs
CSPS
Possibly a tank of bad fuel?
Mileage and maintenance history would help a lot here.
Battery
Plugs
CSPS
With no maintenance history chasing spark plugs is a no brainer in your case. There is a DIY on this forum, I believe.
Based on that mileage, it's your plugs and coil packs. Hope they come out easily enough.
You have 110,000 miles. You need to zero out the maintenance. If you don't have any history, you need to assume it hasn't been done, if you want reliable performance going forward.
Engine air filters
Brake fluid
Serpentine belt
The list is long
Before your next oil change, run at least a tank full of fuel treated with Techron Fuel System Cleaner. You might benefit from doing this twice.
Engine air filters
Brake fluid
Serpentine belt
The list is long
In addition to all the correct advice above I would also check the fuel pressure at the exit pipe of the gas tank right by the fuel pump.
