PDK paddle shifter
Old 04-02-2020, 10:58 PM
desmotesta
desmotesta's Avatar
Received 2,016 Likes on 958 Posts
Originally Posted by CSK 911 C4S
If you have the Sport Steering wheel on a 991.1 the paddles are fixed to the steering column..... they do not move with the wheel.
Are they affixed to the steering wheel on the 991.2's 992's?
nope, you have been misinformed
Old 04-02-2020, 11:57 PM
Yojeffo
Yojeffo's Avatar
They are fixed to the steering wheel.
Attached to wheel
Old 04-03-2020, 12:43 AM
Jack F
Jack F's Avatar
Attached to wheel
Do you like them?
Old 04-04-2020, 12:23 AM
Yojeffo
Yojeffo's Avatar
Originally Posted by Jack F
Do you like them?
Esthetically they complete the look I wanted. Visually exciting and definitely Porsche quality. Do I think they add functionally to shifting gears? No.
Old 04-04-2020, 12:25 AM
Yojeffo
Yojeffo's Avatar
Do you like them?
Old 04-04-2020, 12:45 AM
Jack F
Jack F's Avatar
JCR seems to have the best execution.
https://www.jcr-developments.com/por...llet-aluminium
They are developing Version 2.0 for cars that have the steering wheel manettino. Great value at 575 British pounds. Looks like steering wheel needs to be removed. I’ll have to take the car for a spirited drive tomorrow and see if it seems like the should be longer. I doubt Porsche got it wrong but then again......
Old 04-20-2021, 08:57 AM
malibu515
malibu515's Avatar
What paddle extensions are available for the 2020 992 PDK ?
Old 04-20-2021, 10:36 AM
ICU991812
ICU991812's Avatar
Are there shifter extenders for the earlier steering wheels where the shifter is pull (-) and push (+) on one paddle? I can't seem to find any, and guessing not if they were 3M taped, it would be hard to keep on if you are pushing against the tape also.
Old 04-20-2021, 11:35 AM
isugoo
isugoo's Avatar
For extended shifter paddles, check out Autotechik's. Large enough for comfortable use but not hiding too much of gauges.
https://autotecknic.com/collections/...rs-atk-pr-0008
I think it's still too expensive for what it is though...
Old 04-21-2021, 01:19 AM
NCheok
NCheok's Avatar
Exclamation
https://www.jcr-developments.com/por...llet-aluminium They are developing Version 2.0 for cars that have the steering wheel manettino. Great value at 575 British pounds. Looks like steering wheel needs to be removed. I’ll have to take the car for a spirited drive tomorrow and see if it seems like the should be longer. I doubt Porsche got it wrong but then again......
Vaporware, never materialized for non-GT cars unfortunately. On GT cars, yes it does work as intended allowing you to shift at different points of the steering wheel.
Yes, the steering wheel needs to be removed to replace the shift paddles.
Old 04-21-2021, 09:34 PM
NCheok
NCheok's Avatar
The stuck on contraptions just look fugly and clearly an afterthought that have no place in any Porsche.
Do it right or leave it OEM. Doing it right is never cheap.
Old 04-21-2021, 11:55 PM
Praecox
Praecox's Avatar
[QUOTE=garfunkle;17380801]I don't use m paddles much but the problem is that most people drive with their hands at 10&2 where the paddles cannot be reached. The paddles can only be reached when the hands are at 9&3; where nobody holds the wheel.
Yes, agree... on my 991.2 the very short OEM Porsche paddles force your hands to remain at 9/3 position which can be quite a pain/discomfort... also drive a Lambo Evo with long length shift paddles... very comfortable, hands can be almost anywhere on the steering wheel when shifting... made upgrading to aftermarket paddles for my Carrera a no brainer... paid $95, they look great... do obscure gas gauge so have to move my head a bit, but that’s a small downside...
Old 04-22-2021, 09:22 AM
AdamSanta85
AdamSanta85's Avatar
Received 1,242 Likes on 728 Posts
The paddles are actually different on the GT cars? As per Robert Linton
I believe gold are the JCR and black are his own version
View this post on Instagram
Old 04-22-2021, 09:47 AM
Furrry
Furrry's Avatar
Has anyone noticed the the spring tension on the paddles is not great? On my car I can depress the paddles the paddles a little bit before it actually triggers the gear change. Do the GT cars have the same paddle mechanism or is it tighter?
Old 04-22-2021, 12:08 PM
AlexZTuned
AlexZTuned's Avatar
I’m curious about this too. I wouldn’t mind a tighter spring action or a more tactile actuator feel. A slightly longer “throw” would be nice too, over the “click” on the non-GT 911’s.
Quick Reply: PDK paddle shifter
