2019 4 GTS AC issue
2019 4 GTS AC issue
Today was a nice sunny day in the Denver area. I was driving around and turned the AC on. First I started hearing a quiet squealing noise that did not stop and no cold air. Tried AC mode and then AC MAX mode. Nothing changed. Same low volume squealing noise and the air temp was the same as what was blowing without AC mode. Turning off AC mode made the squealing noise stop. I tried AC on and off a few times but nothing changed.
Any thoughts? Thanks
Take it to the dealer. Why do you want to try and figure it out and be without AC.?
Received 3,443 Likes
When was the last time you used the AC? Mine comes on automatically when I start the car but considering it is somewhat warm here all the time I am ok with it. In the old days such symptoms pointed to a worn or slipping belt connected to the motor.
Your problem could be totally different, however, I had similar symptoms. As it turned out, a rock hit the AC condenser and created a small hole where all of the R-134A leaked out. I had no idea until the AC did not produce cold air. The dealership said that since it was from "road debris," the warranty would not cover it. The DIY wasn't that difficult and it cost me about $300 and a Saturday when all was said and done. You be able to make an insurance claim if the warranty doesn't work out and you do not want to DIY it.
I scheduled a service appointment prior to posting here. Of course I’m taking it to the dealer since the car is under warranty. Just wondering what the issue could be based on what others have experienced in the past. I’m just curious that way. Thanks
Why the low squealing noise?
The GTS has HUGE holes with open arms guiding in whatever is in front of the car. Kind of crazy to have such large openings. Grill screens are a must.
Vinh Nguyen (06-22-2021)
Hey Jack...sounds like compressor to me...I live in the Denver metro and took the cover off and drover her around a bit too...Very nice day. Sorry to hear about your AC not working..
Agree on the Zunsport grills...Just installed the outers yesterday...
The grill inserts are so worth the money for some extra added protection and piece of mind.
I'm really surprised there hasn't been more radiator damage reported on the forums.
Do you where the compressor is located in the car?
