Cleaning Satin Black Finish Wheels
I have a 2019 GTS with satin black center lock wheels and I am having a heck of a time trying to get them clean. I have tried Sonax and Griot's cleaners but there still is a brown tint to them from some type of dirt - I don't believe it is brake dust. A couple of products were recommended but they all could damage the metal finishes in the braking system, etc. so now I am stuck. Went to my local dealer and the guy in charge of detailing said he has run up against the same problem and hasn't found a solution other than putting some kind of glossy finish on them which hides the issue. Any thoughts?
My Carrera 4 GTS now has nearly 12,000 miles. In the two years I've owned it I've tried all kinds of products on the black wheels and was not satisfied. Some time ago I tried Purple Slice which is a very popular product for Harleys and motorcycles. My wheels now look brand new.
jesm (06-09-2020)
I had mine OptiCoated and they were a lot easier to clean, and looked great when clean, but they would not stay that way for long - they started to accumulate that nasty brownish film right away.
The following 2 users liked this post by 911boy:
9ELOVIN (01-30-2020),
sonicworld (11-07-2023)
I had a Cayman with the black wheels previously and I had good luck with the Chemical Guys Diablo Gel. It's concentrated, so you need to dilute in a spray bottle.
https://www.chemicalguys.com/diablo-...wheel-gel.html
I have the same center lock wheel on my Targa. I had them ceramic coated when new. They get dusty but clean up nicely with a high pressure water rinse. You can use a wheel buffer after rinsing if you want but I generally don't.
