Quick oil question...
Old Sep 27, 2019 | 08:52 PM
woodranch's Avatar
woodranch
Default Quick oil question...
Hi, I just arrived in my hotel after a 550 mile road trip from Los Angeles to Lake Tahoe. Here is my question. I just completed my 20,000 service and checked my oil and it was perfect. When I arrived today my oil level was done to low with one bar remaining. I just added a half court but not driving again so I can’t check it now, but that sounds really crazy. Any thoughts? Thanks in advance. I will check for an oil leak under the car but nothing has been on my garage floor....
Old Sep 27, 2019 | 08:59 PM
Class5Kayaker's Avatar
Class5Kayaker
Sometimes those initial oil level readings right after an oil change aren't the most accurate. Do your due dilligence, but I wouldn't freak out too much if you can't figure it out. Assuming you get it up to proper levels and don't see it decrease again in the near future, it was probably an innacurate reading right after the oil change.
Old Sep 27, 2019 | 10:06 PM
woodranch's Avatar
woodranch
Thank you, that makes me feel better but then wondering why the dealer did not put enough oil in it? Right?
Old Sep 27, 2019 | 10:18 PM
CSK 911 C4S's Avatar
CSK 911 C4S
Someone was doing their job correctly.
When the dealer changes oil they use a computer to see the level ..... and they can get it right on the nose the 1st time.
Old Sep 27, 2019 | 10:21 PM
woodranch's Avatar
woodranch
So that really did not help me answer my question or what Class5 said.... maybe someone else can chime in . The reason I am worried is if the oil level was wrong when I arrived tonight, I just added a half quart of oil and is probably overfilled. Shoot, I am a little worried.
Old Sep 27, 2019 | 10:37 PM
Class5Kayaker
Assuming the dealer checked the level properly (car was sitting level when they filled it and they used PIWIS) then you could have a problem (first guess would be filter cover not torqued properly or cross threaded if you don't have any oil dripping from the bottom of the pan).
I was just telling you it could have been underfilled and it might not be much of anything to worry about, so don't freak out, but to do your due diligence by checking on it or taking it back in to the dealer.
If it was me, I'd visually inspect the filter housing (check the various oil change thread on here to see how.....it's easy) before taking it in and you can see if there's oil leaking from there (if it was leaking the oil could burn off and never make it down to the ground, hence no oil spot/puddle, but you'd definitely see it at the filter). If that all seemed fine, I'd continue to drive the car you distance you drove it between the oil change and now and see if the oil level drops again. If it was low again, That's the point I'd take it to the dealer.
But if it's easy for you to get in to your dealer there's nothing wrong with taking it to them now to figure it out.
Old Sep 27, 2019 | 10:44 PM
Duke I's Avatar
Duke I
Your car will warn you of an overfill. I change my own oil and refill with 8 quarts of fresh oil and still have to add 400 ml or so over the next couple of outings to get the measurement to the top. If your reading after you got home was at the bottom you'd need more than 1/2 quart to top it off -- my car is a 991.1, I don't know about the .2 but each bar in my car equals about 200 ml. After I perform an oil change I add 200 ml at a time until it's at the top.
Old Sep 28, 2019 | 01:29 AM
woodranch's Avatar
woodranch
Thanks all, another silly question but checking the oil while you are driving is a complete waste of time and the only way to really know after my addition is by driving for awhile and stopping and then check the level?
Old Sep 28, 2019 | 06:02 AM
Porsche_nuts's Avatar
Porsche_nuts
Correct. But you should really be stopping and turning off the engine on level ground, then waiting a minute or two, and then turning acc on (car on but not engine) to check oil level.
Old Sep 28, 2019 | 07:12 AM
Rich_Jenkins's Avatar
Rich_Jenkins
I believe this is the correct answer.
I'm on a regimen where I fill up at my weekly station. After the fill up, I turn on the ignition and do the oil check. The car has been sitting approximately 3-5 minutes when I do this. The service station I always use is level. I get pretty consistent readings that way (on the third bar, from the bottom).
Adding a half quart would be 2 and a half bars, if I did the math right.
The Owner's Manual for my 2017 C2 states on page 184 that the difference between minimum and maximum oil level is "around 1.4 quarts" (approx 1.32 liter). It also says it is not possible to display the oil level in certain circumstances, which include "vehicle stopped after full-load operation at high engine speeds". So it may not be possible to get a reading after a long trip.
On a side note, hope you enjoy Tahoe. We stayed a week or so on our extended travels and enjoyed the area very much. If you are near Reno,d the National Automobile Museum is worth a visit.
Old Sep 28, 2019 | 08:38 AM
Penn4S's Avatar
Penn4S
This.
Old Sep 28, 2019 | 12:19 PM
woodranch's Avatar
woodranch
Is that correct info that the car warns you of overfill? Because if the reading gave me a 1 bar left and it was wrong, and then I added a half a quart I probably overfilled it. No Porsche dealers here in remote country so that’s why I am freaking a little. Thanks in advance.
Old Sep 28, 2019 | 12:23 PM
LexVan's Avatar
LexVan
Yes. The yellow warning you can drive on. About 200-400mls over.
The red warning does not want you to operate the car. About 500ml overfilled.
Old Sep 28, 2019 | 02:01 PM
woodranch's Avatar
woodranch
Thanks LexVan and to others for there help. Just took a quick drive and nothing came on, so fingers are crossed I did not screw up.
Old Sep 28, 2019 | 02:22 PM
the_buch's Avatar
the_buch
I think the level gauge in the car does some averaging over time so if you went in full it well tend to show that for a while even in the case of an underfill until it averages down to the new actual. I know this as the last time I had my oil changed at an indy it showed full on the gauge for about 30km and then suddenly popped up a fill warning with direction to add a full litre (it turns out it was actually two litres short). Presumably they did not check the level with PIWIS and instead relied on the gauge.
