Installed GT3RS side skirts on my GTS
#91
still not sold huh? mine are coming in tomorrow, I'll post pics when i install them. here are better pics with the skirts installed from another member in case you missed it
https://rennlist.com/forums/991/1165...1-c2s-cab.html
Just curious to see what they look like unpainted. I guess worst case I can get them wrapped in satin vinyl when car goes in for PPF next month.
#92
For those who can not deal with the gap between the side skirt and body these pictures show a solution you might want to consider. I'm of the opinion that any heating of or manipulation of the skirt to conform more closely to the body of the car is not going to work. So my next thought is to fill the gap which I did using Midnight Black ColorFast Tile & Grout Caulk. This was relatively easy and did a good job of making the gap disappear. The caulk matches the skirt quite closely in both color and sheen. Obviously, if you want to take the skirt off in the future you'll have some difficulty but clean up and replacement should not be a big deal. Hope this helps, Doug
1. Was it necessary to use masking tape?
2. It appears toward the front of the car where you stopped with the caulk there are a couple of small hole/air gaps in the caulk. Did you try to hit it once more with the caulk before it dried?
Theres no doubt i'm doing the same i'm just curious if I(or my painter which applies caulk on a daily basis) can get it a tad closer to perfect.
#93
#1 Since I don't believe you can run a perfect bead of caulk for this application it is better to use tape in order to keep the majority of caulk off the car and skirt. You want to get a good amount of caulk into the joint and clean the excess off and tool the joint to make a flat top on the caulk, instead of a dip that you may get by using your finger, especially in the wider portions of the joint. Be sure you remove the tape carefully right after you are done with tooling the caulk. After leaving the first application to dry over night I repeated the process a second time to improve the finished product.
2# You are correct there are couple of small holes present. No, you should wait for the caulk to dry before making any additional repairs. The holes can be easily filled.
Hope this helps.
Hope this helps.
solidwater (05-13-2023)
#94
Hope this helps.
Hope this helps.
#97
They look satin vinyl, but would be better primered than wrapped. best route is to go body color painted.
#99
Yes, what are body panel gaskets and where do you get them? Also, you have pics?
#102
Hope this helps.
Hope this helps.
Can you point me in the direction of the Midnight Black ColorFast Tile & Grout Caulk please.
#103
Received 3,380 Likes
