Before taking delivery, I found 2017 tires on my brand new 2019 911
Hi Everyone,
I am about to take delivery of a 2019 911 and I found it has 2017 tires. The production data of this car is early 2019. Is it normal to have mid 2017 tires on it? If not, what should I do?
Thank you so much guys.
Received 5,407 Likes
What week are the tires for 2017? And tires are produced in large campaigns.
Your car was made in 2018.
Unless you park outside every day in dessert heat and drive only a few miles, you shouldn't worry that much. Spending on how you drive it, it's unlikely the rears will last more than 6000-10,000 miles and fronts more than 12,000-15,000 miles, unless you drive it like a slow Greenie drives a Prius.
drcollie (08-20-2019)
FWIW, when I bought a set of winter wheels and tires from the dealer (ordered from the factory ) they were already 18 months old. If Porsche has tires that are less than 2 years old, they will use them on an ordered car. What my dealer told me.
My 2017 was built in June 2016 and I believe it has tires built in 2015. Aging of tire rubber is a function of temperature and time, including high hearts of you are a track rat.
Received 3,443 Likes
So you are asking if the dealer took delivery of your car with fairly recent production tires, then took those tires off the wheels, did the same with an older car, then mounted the old tires on your car and rebalanced everything? Are there any marks that show where previous wheel weights were? How would the dealer be making money on this?
Your tires are fine.
There's no $$ to be made swapping tires. Make sure you've got the dates right. Car manufacture date is on the door jam and is month and year. Tire manufacture date is on the sidewall and is week and year. For instance my model year 2018 911.2 was build during 10/17 (October 2017) while the tires were made 3717 (week of September 10-16 2017).
The good news, is all the mild release is gone. So, giddy-up.
is it possible to order michelins w/ the most recent production date possible or is it a lottery?
