991.2 S/GTS Pads, Rotors the same as the 991.1's ?
I have been all over the interwebs looking for some brake parts for my 2019 GTS.
Suncoast seems to be the only vendor that has standard rotors for the car and they are double the cost of the 991.1's but appear to be the same. Which leads me to question the pads, lines, studs.... based on what I know the 991.1 & 991.2 brakes are the same.
The next question is if there is any difference in the rotors for the CL cars as much of the reference I can find shows they are the same.
Crap, that is what I was afraid of.
Do you have any leads on blank or slotted rotors and pad numbers? I am showing Pagid 4909 & 4908's for the pads but have no clue where to start on the rotors.
A quick search shows the 997's Turbo's used 350mm rotors, wonder if they would work?
Okay I found this in another tread
Corrected 991.2 S info
991.2 (991.1 in parentheses)
Carrera F: Ø 330 x 34 mm (Ø 330 x 28 mm)
Carrera R: Ø 330 x 34 mm (Ø 330 x 28 mm)
Carrera S F: Ø 350 x 34 mm (Ø 330 x 34 mm)
Carrera S R: Ø 330 x 28 mm (Ø 330 x 28 mm)
997 Turbo F: Ø 350 x 34 mm
997 Turbo F: Ø 350 x 28 mm
Unfortunately a (2) piece rotor is overkill, I need to do some testing & tuning before a big Time Trial event so maybe 5-7 track days total then back to street duty. I was hoping to buy a set of brakes to swap while the car is new so I can put them back on when I put it back on the street.
You could also do a gyrodisc slotted rotor.
It is a 350 mm diameter so conversion would not need standoffs. Replacement rotors are cheaper than the OEM ( if you replace just the ring).
I have a brand new set of 991.2GTS MY2019 brake set in the classified area.
They have 1.000 miles as i have upgraded to PCCBs.
Price is Half of original price and everything is Porsche OEM.
PM me in case of interest.
In hopes that I might get lucky I did order a set of 997.2 Turbo Rotors and will test fit these when I get some free time.
Okay I have some great news, the 997.2 Turbo Front rotors is a direct match to the 991.2!
Unfortunately the rears are smaller but they are a match to the 991.1’s. Now to either put in spacers or order 330mm rotors.
Updated Measurements
997.2 Turbo F: Ø 350 x 34 mm
997.2 Turbo R: Ø 350 x 28 mm
Front 997.2 Turbo rotors vs 991.2 S rotors
Front 997.2 Rotors on a 991.2
Rear 997.2 Turbo 350mm vs 330mm 991.2 Rotors
330mm 991.2 Rotors
350mm 997.2 Rotors
330mm 991.2 Rotors
350mm 997.2 Rotors
tgavem (12-19-2020)
Yes 1:1 replacements. Note that the OEM 991.2 are higher quality than the older rotors as they are a (2) piece cast design but they ruined them by cross drilling. With a good driver I would only expect to get a few weekends before cracking.
991.2 S Front Rotor
