Aftermarket Porsche PDCC
Old 08-12-2019, 08:34 AM
  #31
worf928
worf928's Avatar
Received 1,679 Likes on 1,089 Posts
Originally Posted by Psorcery
It's not as easy knowing which does and doesn't have PDCC unless you have significant seat time in both or you're on a test track.
A person who has no idea of this option on a Porsche wouldn't be able to tell the difference. They'd be just as blown away in a non PDCC car.
Pretty much this—-^
Old 08-12-2019, 09:28 AM
  #32
AdamSanta85
AdamSanta85's Avatar
Received 1,245 Likes on 730 Posts
Just look at sway bar end links, it will take all of 5 seconds to get down and take a look, and will immediately tell you if you have PDCC or not.
Old 08-12-2019, 03:55 PM
  #33
doctorayes
doctorayes's Avatar
Mystery solved! The car definitely has PDCC and it was missing from the build sheet for some reason. I spoke to Trophy Performance in NV and they confirmed they had installed an aftermarket Porsche sport exhaust. Thanks for everyone’s advice and help :-)
TurboS_GG (08-12-2019)
Old 08-13-2019, 12:32 PM
  #34
MJG911
MJG911's Avatar
Originally Posted by doctorayes
I am assuming because the car was CPO that they would take out what doesn't belong. The dealer certified this care as having PDCC and sport exhaust (which works perfectly) although these two options are not on the build sheet. Retrofitting a sport exhaust is easy but I agree there is too much work involved with retrofitting PDCC. I called the dealer and they are working on verifying that. In the meantime looking at this build sheet the options do not add up to 129,000, What do you think? I am now leaning that this car has had PDCC all along but the build sheet is inaccurate. unfortunately, the car is in the shop for PPF so I can't look at the wheels or the engine but I will know soon. But again do these options below add up to 129,000, please let me know.
the similar sheet for my old GT4 was also missing items.
Old 08-13-2019, 03:50 PM
  #35
Hurricane
Hurricane's Avatar
The build sheet on the COA for my first 991 was incorrect as well - PCNA printed me a new one.
Old 08-14-2019, 03:54 PM
  #36
doctorayes
doctorayes's Avatar
In the final episode of "Do I have PDCC?" and in unexpected turn of events I can say I was wrong and the car does NOT have PDCC. The build sheet is unfortunately correct. What happened was, the wrong button was installed when the car was retrofitted for sport exhaust system. I rushed to conclusions earlier based on my PPF installer initial glance at the sway bar and links. The car was checked at my local Porsche dealer. Thanks again for all of you!
NightBlueTTS (08-14-2019)
Old 08-14-2019, 04:12 PM
  #37
NightBlueTTS
NightBlueTTS's Avatar
Occam’s razor
Old 08-14-2019, 04:49 PM
  #38
LexVan
LexVan's Avatar
Received 5,413 Likes on 2,516 Posts
If people ask, tell them that button is for the Porsche Dynamic Carbon Control.
Old 08-14-2019, 05:02 PM
  #39
the_buch
the_buch's Avatar
Sounds like a discount should be in the works from the dealer?
  #40
sr5959
sr5959's Avatar
At least you have the button that’s the most important thing! 😊
Old 08-14-2019, 05:22 PM
  #41
doctorayes
doctorayes's Avatar
Originally Posted by NightBlueTTS
Occam’s razor
Exactly!!
Yup, indeed!
Old 07-13-2020, 09:38 AM
  #42
garfunkle
garfunkle's Avatar
Received 1,150 Likes on 630 Posts
Originally Posted by NF4710
When the sport exhaust is added I believe you have to change out the center switch panel. Perhaps they ordered one for a PDCC car and that’s why the button is labeled so.
Just a guess.
NF
When you need a single nw switch, the only way Porsche sells them is an entire new assembly with ALL of the switches that are installed and the dealer configures to do what the picture on the button states.
Old 07-15-2020, 10:00 PM
  #43
CanyonBlaster
CanyonBlaster's Avatar
My car has PDCC and the shock setting button does not display "PDCC"
WP0AB2A95CS120165​​​​​​
Old 07-16-2020, 10:53 PM
  #44
bb964
bb964's Avatar
Neither does my 2012 with PDCC. They must have changed the button in later years. What about '13, '14 cars?
Old 07-16-2020, 11:29 PM
  #45
visitador
visitador's Avatar
^^^ this discussion keeps coming up. The button changed in 2014 to show the PDCC letters, I believe. It is meaningless bc PDCC is always on. Pressing the shock absorber button just means it is in a more active setting
Quick Reply: Aftermarket Porsche PDCC
