Flat tire
Old 07-23-2019, 06:26 PM
Loud223
Loud223's Avatar
Default Flat tire
Got a message that my right rear tire was 6psi low. I found a screw and removed it and tried a tire repair kit I bought for my track kit. Screw came out easy as did the air in the tire. the reaming tool went in & out easy. But when I tried to put the plug in, it would not go through the hole. I tried twisting, banging the tool with the palm of my hand. nothing worked. finally after much cursing it went in enough to stay when I pulled the tool out. seems to be holding air but Ill check it in the AM. This was done in my warehouse at work on a lift. couldn't imagine doing this on the side of the road. Anyone have tips? or did I forget a step?
Time for new shoes!
Old 07-23-2019, 06:37 PM
VII7
VII7's Avatar
It's easier working downwards with the weight of your body (tire removed).
Old 07-23-2019, 06:44 PM
Joec500
Joec500's Avatar
Received 1,009 Likes on 600 Posts
^ THIS
I also carry one of these in my car, I have yet to use it *knock on wood* but it seems like a better roadside solution for ease of use.
http://www.dynaplug.com/instructions.html
Old 07-23-2019, 06:49 PM
Porsche_nuts
Porsche_nuts's Avatar
Received 1,184 Likes on 711 Posts
I just found out I have a flat on the rear right (seems everyone gets a flat on that tire). Haven't had a chance to look for the culprit, will do so tomorrow.
Crap
Old 07-23-2019, 06:57 PM
Joec500
Joec500's Avatar
Crap
Prob cuz it's the widest tire and closest to the shoulder where nails etc like to hang out.
Old 07-23-2019, 06:58 PM
arter
arter's Avatar
Did you slather it with adhesive before inserting it ( this lubes it up).
Old 07-23-2019, 07:03 PM
Loud223
Loud223's Avatar
Yes I did. No help.
Old 07-23-2019, 07:25 PM
LexVan
LexVan's Avatar
Received 5,402 Likes on 2,513 Posts
Does your plug kit have the rasp tool?
Old 07-23-2019, 07:53 PM
Thinc2
Thinc2's Avatar
Yes, I still like childish humour
Old 07-23-2019, 08:27 PM
Jack F
Jack F's Avatar
https://www.amazon.com/ARB-10000011-Speedy-Repair-Universal/dp/B075CR4J3W/ref=sr_1_3?keywords=tire+repair+kit+arb&qid=1563925120&s=gateway&sr=8-3 https://www.amazon.com/ARB-10000011-Speedy-Repair-Universal/dp/B075CR4J3W/ref=sr_1_3?keywords=tire+repair+kit+arb&qid=1563925120&s=gateway&sr=8-3
Did you used something like this?
Old 07-23-2019, 08:35 PM
LexVan
LexVan's Avatar
Our tires have an amazingly strong internal carcass. You need to rasp the puncture, or else you're never going to be able to get the plug and plug tool into the tire.
Old 07-23-2019, 10:02 PM
CSK 911 C4S
CSK 911 C4S's Avatar
I had to plug my right rear this past weekend as well.
Old 07-23-2019, 10:32 PM
Loud223
Loud223's Avatar
Yes, sorry I called it the reamer. the rasp went in and through the inner wall.
Old 07-23-2019, 10:38 PM
Porschetech3
Porschetech3's Avatar
Received 4,579 Likes on 2,074 Posts
Pro tip : overinflate the tire before attempting the tire repair. This will make the insertion of the reamer and tire plug much easier and the plug will hold better. Trying to ream or insert the plug tool on a tire with very low pressure is difficult and the plug will not hold as efficiently.
The following 2 users liked this post by Porschetech3:
Jack F (07-23-2019), One N Done (07-23-2019)
Old 07-24-2019, 10:41 AM
Loud223
Loud223's Avatar
Originally Posted by Jack F
Yes, Something very similar
Quick Reply: Flat tire
