Five gauge pods, I can only see 3. What do you use in the info pod?
All I care about is the tach with the digital speed display and the multifucntion screen to the right which shows the vitals and distance to empty. A simple scroll to check tire pressures at the start of every drive. Rest of the guages I don't even look at.
I love that multi-function display it’s very useful. Least useful gauge for me is the analog speedometer. No need for it when you have the digital Speedo in the rev counter. I wouldn’t mind if the Speedo was a 2nd multi-function screen.
I suppose you can get a duplicate gauge on the multifunction with the oil temps as well. I guess I just love analog gauges.
Miles to empty
Cool temp
Oil Temp
Oil pressure
Miles & time to next stop-over (only active when running a multi stop route in Nav)
And the "one touch" feature on the steering wheel (the diamond icon) is set for tire pressures
Cool temp
Oil Temp
Oil pressure
phefner (07-19-2019)
My wife’s ‘19 Cayenne has exactly that setup; two Multi-Function displays. The only analog instrument on the cluster is the central rev counter.
sr5959 (07-19-2019)
Lex, is this feature available on a 2013? I believe I have that button not sure how to set it. Thanks.
I figured it out thanks....it’s set via Settings on the multi-function display using the right steering wheel button. I set mine to scroll through audio sources because I normally listen to BT audio from my phone, and this is the only car that I’ve had that defaults back to radio on every start! 😊
sr5959 (07-20-2019)
