Five gauge pods, I can only see 3. What do you use in the info pod?
![](https://photos.smugmug.com/Porsche-911/Porsche/i-NPcLMc2/0/6d8e5c94/L/2019-07-18%2016.09.16-L.jpg)
I can only see the middle three gauges, and even then sometime just the center one. I have to lean in and move my hands to see the gas gauge.
I leave the "Info pod" on Torque split, because its pretty benign and has range and time/tempi on the top and bottom.
What's your go to Info Pod?
Speed limit at top
Distance till empty
Compass
Engine oil temp
Battery Amps
Time and outside temp at bottom
Distance till empty
Compass
Engine oil temp
Battery Amps
Top: Compass
Middle Section 1 - Oil Temperature
Middle Section 2 - Oil Pressure
Middle Section 3 - Blank
Middle Section 4 - Blank
Bottom: Range to Empty
I figure first I want to know basically what direction I'm going. I always use a compass if I have it available. Then I like to know when the oil temp gets above 150. IDK why. Maybe I read it somewhere. Oil pressure because if it drops, I want know (although I am sure there is an idiot light somewhere that would go off.)
Range is last because I like to keep an eye on it.
The two lines are blank because I prefer to keep information in my eye line to stuff I need to know to make a driving decision. I can't imagine why I would want to know battery voltage, or turbo boot pressure, but that's just me.
This screen is what's tied to my "Diamond" button on the wheel.
Received 3,432 Likes
Temps or tunes.
On many modern cars, you can't adjust the steering wheel low enough. IN many cases, the lowest position is still two ro more inches too high.
boost
oil temp
water temp
oil pressure
Those to me are the ones to watch when driving hard/on track.
oil temp
water temp
oil pressure
