SOUL Sport Cats owner please chime in
So I just had the sport cats installed on my 18 GTS and am not sure if what i'm hearing is normal. The car really does sounds a hell of a lot better but I noticed under hard acceleration it makes sort of a hissing noise, almost like a small exhaust leak. Maybe its just me but it doesn't sound as crisp as it was with factory cats. Theres a chance the install wasn't done properly but the installer is a long time Porsche specialist so I would be surprised if that's the case. Could it still be breaking in? Only driven about 10 miles since install.
I do hear Turbo spool but thats not what i'm describing(at least I don't think).
I know you have the Cobb tune. Can you tell me how I can check to know which map mine is running? Just picked it up yesterday and haven't plugged in to my car yet. Car feels strong but I can't say for sure as I haven't been able to really get on it.
Received 3,460 Likes
No new sounds/noises other than some mild turbo spool with Soul high-flow cats on my '19 GTS.
I believe what you are hearing is the turbo spool. I had the Soul cats and what you are hearing is normal.
On he Cobb handheld AP.. Plug it into the car and go to the area where you can change maps. it will tell you what the current map is.
ummmmm yea there's a very obvious difference. Didn't go too crazy but this thing hauls a$$. I'm still convinced that something isn't right with the cats. Will soon find out.
That could be a better way of describing it. Love the turbo whistle and the sound of the exhaust is perfect I’m just not convinced that iits designed to sound this way even though It’s only noticeable under WOT.
I had SOUL cats installed at a Indy shop and noticed that the turbos(s) spool up “whoosh” was much more pronounced. Me being OCD, I went under the car and made sure that all the bolts were tightened properly. I did this when I installed the headers myself. If you suspect a leak, definitely have it checked out. I personally can’t imagine a leak, unless there is a crack somewhere, since these cats were a perfect fit.
