Michelin rear tire average mileage
Needless to say, those who are more concerned with tires lasting can increase the pressures albeit it will be more firm. I would like to know the exact pressures that seffeed is running...
Thanks. I know they probably feel good that low but you may try running them higher, especially when you get new ones. I am running 35/40 on new P-Zeros and they feel fine for the street. The roads around here are pretty good so that matters as well but don't be afraid to play with them since again, if you run them a little higher they will last longer.
Right about 20,000 non-track miles, replaced in July 2018.
The left rear was not corded. This right rear was slightly out of alignment, when it was done (for the first time in over 58,000 miles).
LexVan - I see what you mean by bad alignment. Mine look worse. Should be ready for pickup today after new set and alignment.
