Carrera T buckets - anyone investigated adding rear seats?
I'm in the market for a Carrera T and would love to get the buckets, but I do need rear seats as I plan to DD the car and need to be able to put my kids in the back (buckled in, not just rolling around
Most people will just say get the non-buckets and call it a day, and I may end up doing that, but thought I would check here to see if anyone had looked into putting rear seats back in the Carrera T with buckets. Unlike the GT3, I am thinking that a Carrera T with a rear seat delete may very well still have the mounting points, etc. for the rear seats and seat belts under the carpeting.
Anyone have any experience with this, or checked the rear of a Carrera T to see if this is the case?
Thanks in advance...
I have looked into it. Evidently with the buckets there is some bracketry missing that would be needed to bolt the rear seats in. I am sure it is doable-however you may have to come up with some mounts/fab up some brackets. I ended up getting the t without buckets and may eventually do the 997 carbon buckets that are foldable. This way you can enter the back without having to be a contortionist .
The LWBS do not fold so getting behind them is near impossible. If you need the back seats get one with them and then buy the 997 foldable buckets as polobai suggested. The fixed backs would not work at all for what you want to do.....
I investigated the same thing. Might be cheaper and simpler to get a regular seat T (or S even better), and add lightweight aftermarket buckets.
Numerous vendors selling CF seats for a fraction of the OEM cost. Even going OEM from parting cars, it's potentially cheaper than adding seats to the back, not to mention safer.
I'd look for a T with back seats and then look into confirming that these will work in a NA Carrera T:
http://carnewal.com/products/991/p91...-:-991-version
Sat in a 991.2 GTS with these in the UK and they felt even better in the 991 platform than they did in the 997 platform—seemed to be mounted lower, which was the only downside to them in 987s and 997s (for me, anyway). They're light, hold me better than the 918-style buckets available in some 981s and 991s, and maintain access to the back seats. Only thing I'd want to be sure of is that the airbags will work as designed in a US car.
Not cheap nor easy and not a dyi project. May be easier to buy a car with sofas, then buy a set of 991 euro foldable bucket seats.
The T when ordered with buckets is missing a crucial bracket on the inner fender liner which is same a gt3.
https://rennlist.com/forums/991-gt3-...is-doable.html
LWBS are a big commitment. Depending on how you plan to use your car, they can be a detriment to everyday livability.
I’m getting an option to buy a T with the 14 way seats but the car doesn’t have rear seats. Is there anyway to add the rear seats in? I have small children so rear seats is a must for me. Thanks in advance.
https://nemigaparts.com/cat_spares/p...2/547u/801350/
should behind where there is a dimple or hole on your rear interior plastic panel. This bracket is used for a bolt to secure the seatback.
This bracket is not there on GT cars or cars ordered with LWB.
Also, check if you have rear airbags.
I have LWBS in my car and confirm that even with the seat moved all the way forward, it would be near impossible to get in behind them. You probably would spend the same money retrofitting a questionably safe rear seat (not to mention insurance issues) as you would on sourcing some foldable buckets. Maybe even the euro spec foldable seats.
Either way you’re going to spend lots of money on this and won’t get it back at resale. If you need rear seats so badly, why not just get the 18 ways and call it good? They’re pretty good seats. The carbon seats are more bling for a daily driver anyway and far less comfortable.
This could be specific to your area where you can have 14way and no back seat. Need to check behind cover on C-panel to ensure you can attach seat belts, pull back carpet and side panel and look for the bracket shown on part 4.
https://www.suncoastparts.com/produc...EATDELETE.html
Has anyone confirmed if the foldable buckets would throw an airbag light with the sliding 4ways? Also how big of a project is the mounting bracket?
Pete, do you know anyone thats done it?
Unless the foldable buckets have the integrated thorax airbag, removing the OEM seats would cause an airbag light. It may be possible to trick the ECU into thinking a non airbag type seat is installed which would mitigate the airbag light problem. Not certain though.
