Which colour would u choose?
Received 3,455 Likes
I bought a couple of sample sheets of this for a special project or two I am working on: https://www.apafilms.com/product/gloss-miami-blue/
Not sure bout US. I'm from Malaysia and car wrap here is cheap. 800 usd for everything with 2 years warranty. Dun need to b jealous tho as our cars r freaking expensive. Bout my used 16 Carrera s 991.2 for 165k usd haha
I'm a big fan of wrap, but man would it be nice for some kind of magical tech to be introduced to massively lower the costs. Seems pretty much impossible in the real world as labor will always have to be a factor.
sorry for my ignorance. but you can essentially wrap a car with any color these days?
and it looks good?
so if in a year or two, I wanted to change the color of my blue 911 GTS to a silver, I can do that?
and it looks good?
Looks Good? Well, that all comes down to the quality of the installation....
Vinyl wrap can be installed, left on for an hour, a day, or 5 years and you can remove it and replace with a different color, or just leave it off and return to your original paint color. If it was installed properly, without a lot of edge glues and trimming on the paint, your paint will look just as it did when you installed the wrap.
Yes, there are thousands of colors that you can choose from, from a number of manufacturers. Similar to selecting paint nowadays....
Thank you.
Voodoo of course
Mmmmmm....voooooodoooooo....mmmmmm
Its about 1/3 the cost of a wrap and its sprayed on but it peels off like a wrap. Like anything sprayed it comes down to prep but a highly prepped car with all rubber taped/masked and the removeable parts like lights removed comes out really well done. I also like the fact that the major parts like bumpers and trim do not need to be removed so the chance of developing rattles because the installer didnt put everything back right is greatly reduced. it also can provide a more even finish on complex areas like GTS bumpers, etc. Ive seen wraps start to peel up in corners after a few heat cycles but a sprayed on wrap will give total coverage without the 'shrinkage' risk in corners.
this is mostly a color change technology and has its limitations. I think wraps will last a little longer and I think the liquid wraps can be susceptible to chemicals like a few gasoline spills, etc. Poor application seems to be the biggest risk with overspray, etc. just like a paint job.
the new 'Liquid Wrap' technology is very compelling. It started as Plastidip type technology (which I wouldnt put on my paint) but the new tech is put on with 8-10 coats and can be done in gloss(autotech I think is the name). it can also be wetsanded to get a near paint finish (new tech is used by people that show their cars, can be a very nice finish).
Autoflex is the name BTW, not autotech as I originally wrote
