Carrera T + more power = the perfect driver's car?
Old 02-24-2019, 09:07 PM
  #76
Ukkid74
Ukkid74's Avatar
I did 5 mil spacers all around & Akrapovic cats, pipe and valance. Super happy on a dyno jet dyno is was 383hp to the wheel 🤷🏼*♂️ I was gonna put springs on it to go a little lower but didnt get the factory raise kit and my drive sucks. Have a little road rash already from Rallys etc. T is one awesome car
fyi - my buddys stock GTS only pulls slowly from me iat the end of 3rd and 4th gets a car and 1/2 away
matty
Old 02-24-2019, 11:37 PM
  #77
groundhog
groundhog's Avatar
Received 1,037 Likes on 657 Posts
Originally Posted by Ukkid74
I did 5 mil spacers all around & Akrapovic cats, pipe and valance. Super happy on a dyno jet dyno is was 383hp to the wheel ����*♂️ I was gonna put springs on it to go a little lower but didnt get the factory raise kit and my drive sucks. Have a little road rash already from Rallys etc. T is one awesome car
matty
Good to see someone putting their Series 2 to use in rallying - what types of event are you doing? duration, number of legs stages and overall distances. Within reason, in road rallying its not so much about power but rather nimbleness - for very technical rallys I actually prefer my 981 GTS to my 991.2 GTS. I have only back to backed a T and GTS once and found the GTS "jogged" away from the T on a straight line pull. Ifound the difference from the drivers seat to very noticeable particularly up top.
Old 02-24-2019, 11:42 PM
  #78
supercroc
supercroc's Avatar
Originally Posted by 4pipes
Just curious, any consideration given to other engine and driveline limits? Bearing loads, piston ring sealing, oil flow and cooling, transaxle and clutch loading?
From 370 to 700+ is a big step.
Wondering about this myself as the Technik Manual shows 406 lbs. ft. as max torque for 7 speed manual trans (GTS is 405 - imagine that!). Assume there is some safety margin but . . .
Old 02-24-2019, 11:53 PM
  #79
groundhog
groundhog's Avatar
I think the torque limit is artificial e.g. peak torque for the 3l turbo is rated at 550Nm = 405/6 ft lb. Yet the cogs in the case of the PDK are from the turbo - the rating may reflect the clutch plates. However, if you tune the car and exceed 550Nm meters ................Porsche will have valid grounds to deny warranty for the transmission. Hence it is better to get the X51 turbos and tune to 550Nm e.g. you get the benefit of power across the whole curve rather than low end peaky delivery of some tunes on the OEM base turbos. Costs a little more but the outcome is better all round.
Old 02-25-2019, 12:00 AM
  #80
PCA1983
PCA1983's Avatar
If you do the conversion from the 550 Newton - Meters to ft-lbs, it's 405.7 ft-lbs, which we engineers round off to 406. So there is no discrepancy.
Old 02-25-2019, 01:12 AM
  #81
G99x.y
G99x.y's Avatar
What happens if you transplant the gts turbo but don’t do a tune? Slight less than 405 ft/lbs, Error codes?
Old 02-25-2019, 03:05 AM
  #82
Psorcery
Psorcery's Avatar
Not good.. You'll need GTS cats or better too.
Old 02-25-2019, 10:32 AM
  #83
G99x.y
G99x.y's Avatar
matty
What did you notice different after adding the 5mm spacers?
Old 02-25-2019, 11:42 AM
  #84
991.two
991.two's Avatar
I would think the air/fuel ratio will lean out and the ECU will try and correct it. But I don't think it will make a correction that large.
Old 04-11-2019, 11:20 PM
  #85
TXGold
TXGold's Avatar
Originally Posted by joshd
I guess I'll need to do this near a gas station!!
Bad thing about this data is that it's going to show my slow granny shifting!
No word from @JoshD in 3 months. Whats the story here?
Old 04-12-2019, 12:03 AM
  #86
TXGold
TXGold's Avatar
Hasn't logged in since 1/30/19. Hope he is ok. Curious who the tuner was.
Old 04-13-2019, 02:01 PM
  #87
PCA1983
PCA1983's Avatar
Maybe he already traded it for a GT350 🤔
If it's the 1st Porsche, they often aren't married. This one is my 10th Porsche since 1970, so I'm not going to another brand.
Old 05-03-2019, 09:46 PM
  #88
Rennolazine
Rennolazine's Avatar
Originally Posted by Psorcery
It better be. I want first gear back.
The whole point of a Porsche is to have all the traction possible.. While I'm not at 700hp I still have an unusable 1st gear on stage 2 and I'm beginning to spin 2nd.
If I were you I'd be eyeing down matching or beating a 720s. You need first gear.
Love your build so far.. I like your style. All action.
Im in a similar traction situation and only stage 1 with full exhaust... on Stock base turbos. Cant even imagine another 80 hp. Its already a beast. Guess u just gotta learn how to drive a fast car slow.
Old 05-03-2019, 11:11 PM
  #89
Norge911
Norge911's Avatar
deleted
Old 05-04-2019, 01:48 PM
  #90
Taxi
Taxi's Avatar
Why not fitting Porsche Powerkit Part.No. 991 044 100 10 with 450 HP (including greater turbos) to the Carrera T?
Quick Reply: Carrera T + more power = the perfect driver's car?
