Custom Hood Crest
#106
Received 3,365 Likes
Yes. From what I understand the crest is riveted on and it would require prying it off and using a dremel to grind off the posts, or take the airbag a part and see if there was a way to get it off easier. Jim put 3M tape on the back but I removed it and put 3M tape on just the airbag crest so it would sit better. I remember reading that someone else used some kind of adhesive but using thin 3M tape allows it to be removed easier, if so desired at some point in the future. Mine is bigger that the one that Grasox has on his airbag (see above) and that is the one I am sending Jim to refinish to replace the one I have on it now, which will sit more flush on the stock crest as you can see.
#107
#108
what about the stitching in the steering wheel in blue?
#109
#110
Speaking of crests, here is an illustration of how the crest evolved. Note some very minute differences from one to the other; I am going to use the one on the far left for my steering wheel (1 5/8" high) to replace the one I have now:
#111
Do you have an airbag that could send it into your face? Maybe they don't do that when deployed? Just would prefer soft leather or plastic bag vs other possibilities.
#112
As I think I already said to someone else here, I like the way it looks much better than to worry about something that is to likely never happen, and I am pretty sure when the airbag deploys the cover opens to one side of the other (my wife/passenger feels the same way).
#113
#114
So I wouldn't sweat it either Bob. The odds are low the airbags will ever deploy. Lower still that, if they do, it would cause an issue.
#115
No worries here and again, I like it so much that being maimed is not a concern. Jim is refinishing the 356 hood handle crest I sent him so it should look much better when I get it back, like the one Grasox has on his steering wheel.
#116
I stumbled across this site that has some custom crests but I do not know how the quality is compared to Carrera East: https://www.aasesales.com/collection...-badges-crests
#117
Seriously been emailing this dude since December. Zero response. Anyone in contact with Jim?
#118
By the way, he does have a few on ebay that you can find by searching for "refinished crest", and his new User ID is interestedparty. Here is one he has there now: https://www.ebay.com/itm/GENUINE-POR...cAAOSwWxNYttRP
#120
He has a few on ebay that would look good on both of your cars...
