Carrier bolt not lining up. Help plz.
Replacing the serpentine belt and all going well until trying to get the carrier bolt back in. Seems something is out of line I don't want to persuade it too much.
I did loosen 3 bolts surrounding it.
Dude you are kidding me.
I know this is the "technical" forum but you will find very few people here that know how to turn a screw driver.
Plenty of "what color contrasting seat belts should I order" guys...but sadly that won't help you.
Received 5,402 Likes
Without a more definite response so far, I'd guess that the engine settled a little in relation to the carrier and the bolt hole. You may need to find a safe jack point to lift the engine just a tad, it probably wouldn't take a lot of force, cushioned by something to spread the load like a block of wood or rubber.
This would only be a possibly correct answer if the targeted bolt hole (threaded part) if slightly lower than the hole in the carrier. I can't tell in the photos.
I just looked through the detailed shop manual and don't see anything addressing alignment when resetting this bolt.
I no longer have a 991.1 to look at, the 991.2 has a plastic pan so I can't compare. Looking at the 991.1 shop manual (link at the bottom), it looks like you can but I'm afraid to be responsible for saying yes if it goes bad
. I'm looking at page 5247 in this manual I've put up on my DropBox.
https://www.dropbox.com/s/fi41obpz9f...anual.pdf?dl=0
100109 LOWERING THE ENGINE .
3.1. Support the engine at the oil pan using hydraulic garage jack H 2 SL WE 1032 and transmission jack plate of transmission jack V.A.G. 1383 A WE 1082 .
The 997.2 and the 991.1 engine are effectively the same. I do recall that I supported the engine on my 997.2 at the oil pan (back edge I think) using a 4x4 with a jack.
I can't find any mention of this on the 991 forum, but in the 997 forum I found this so far:
https://rennlist.com/forums/997-foru...s-porsche.html
I also see a 996 engine being lifted similarly at the 13:30 point in this YouTube video (link includes offset to that time, he may show it earlier but I found it here skipping ahead):
Edited to include 996 reference since it may not be apples to apples.
Good job. Glad it worked out.
A good number of DIY folks tackled belt replacement.
Good to know a little lift and it lined up.
And, StormRune, you rock!
Reenlist is always been a big help. This was a diy weekend:
- new serpentine belt
- install PSE
- install PSE panel switch
- platidip rear bumper emblems
- paint rear bumper reflectors
Need to dial a few things in but got it all done. The car goes to the dealer on Wednesday for PSE programming.
- install PSE
Acampo, how many miles on the belt? How'd it look?
I just got the car last week - 2012.5 with 16k miles.
The belt looked fine, but since I had everything off I thought I'd spend the $30 bucks on a new belt. Even though I did have some frustration with the carrier bolt.
The way I look at it, I just renewed my man card for another year.
