Another PSE install question.
#31
A new wrinkle. When I was driving home form the dealer, a coolant system failure code popped up on the dash. An odd coinciendence. I did a quick search and that could be tied to a bad COV.
Looks like it's gotta go back to the dealer. If so, I'll have them look over the exhaust when they have the car apart.
I hope this gets resolved for you soon! Please let us know how it turns out,
#32
I think I'll try and fix it myself before going to the dealer. I got myself in this position, I'm sure I can figure it out. Guaranteed it's a install error I made. Over the years, I've learned that often times the fix is easier than you think. In this case, I just have to take the entire rear end of my car off.
I'll report back on what I find.
I will say I loved the glorious sound when I opened the valves manually.
#33
Ok. Making progress.
I forgot to remove the second vacuum line from the standard S exhaust.
Now I'm left with 4 vacuum lines and not sure where/how they connect.
#34
A quick update. I got the vacuum lines all set up. I was just overthinking it.
However, the PSE still wouldn't work. It was stuck in quite mode. I could hear the valves trying to open, but there wasn't enough vacuum. I could also hear the COV relay clicking loudly. So, I put it all together and decided it had to go to the dealer. As I was driving there, I noticed my heat stopped working. Now I'm thinking a COV went bad and maybe I'm not as bad of a mechanic as I thought.
Long story short, the dealer is looking it over. Agreed it might be one or more COV"s and it would be covered under CPO. Fingers crossed on I can finally hear that PSE by tomorrow. DC weather is warm and sunny for the next couple of days. I'd like to get out and scream it a bit before putting it away for winter.
Thanks for everyone's help.
#37
There are 8 COV,s in our cars, and from what I understand, no way to find out which COV is bad. Each has to be tested to find the bad one. Have you had the dealership program your PSE button yet??
#38
Yesterday they said that they felt the COV's tested fine, but they're still trying to track down the vacuum leak. I'm hoping to hear from them any minute with an update. They've had it since Monday.
#39
Still at the dealer. I'm getting a bit of the run around - "tech's leaving for the holiday's" and "hope to get to my car tomorrow".
I'm trying to remain patient since I know this this is related to the PSE install I did. I want to make sure it's covered under the CPO. Don't want to burn any little good will I have at this point.
#41
edit: replaced the COV as suspected failure point, everything works as it should now. about 90 mins to replace and put back together / put tools away / giggle while you press the button and rev it up a bunch
#43
http://plenums.blogspot.com/2016/10/...-overview.html
#45
If memory serves me correctly it was to the right side of the airbox behind the taillight crammed in there around the passenger side intake manifold area. I looked through old pics but couldn't find exactly where it was, but I believe mine was #3 from this graph :
![](https://3.bp.blogspot.com/-uxopxjsbCjE/V6CyybkVJkI/AAAAAAAACkg/rsnSbXttbR8PtLSWwcJQV2t_WT_rh4zXQCLcB/s1600/991%2BCOV%2BLocations.JPG)
![](https://lh3.googleusercontent.com/YhxErvGv_28G-zFpaF96hagGcYMKdZTi_Ucff9PCwW7oDmY39LQ3jHUlkdcqdKKfd5gzbb0uVoIce7G9aczgih9CNN99nFqlLii9LbaFN3fiRAf3UmnN3-bs2A-ehNYFpAlzxRCthYoat2TbWmu8wmyMgxKXOa2rwUynRr7qpNC25VSrlNAMj-tlzcwTvATnazMv-GHlZSCIzrfOGGiBALPWQDqpTW6jJbVoX7JHeSTu5n0McGhfmGci6dv30z3zfpeWqnIGPmnqDsqPKeiZrzyPJ-fHawov5uHv6QoB_CJx33ZwhPV1Aw_5cWspkbcq_L8iK_DVaCN3QJ_igOHg72gOEG1ZajN-HVoixSEmCtO177a-bgwHftqU0FyGiqw0mWkAItRlYzsIGwY1aAmdSumjeaGfimH6iVittvqNuncPjFNOrhb1CAQEZ89tCS1dvncNvUeiKwixomJ7QiBJvCxApegQpCrdnWac9KDHiYdPSYwi8dnUtkoKtnU4Efw8mJhQsrzxJ6muFe1pP34Vy6WTU7ZfVOBd7_bZwRCHc0mPj4HdvT-HKjF6MO-eOjNwV_cVg8iEC0dN52b97vSohK8sdqTLWC-2_-vHtW-Xb7BxKryJP7306ko_ewKjqxc9JVA-uwGrDD0KnKRGOr_2AQSTyHwjIaaEg5Tskntq4VX59W8Tv7IYKh5bu8iAFQ=w727-h969-no?authuser=0)
![](https://lh3.googleusercontent.com/YtevrYrCy3AjpqGo1fwG1TCnngnMqnMgxgw6nFvBD7tBYp-Q7OvCrm5Q25WFi4abX84nIvpKPKniINxrcKzEoAUEn19Awq0oRb06slxkGc38tUI6E8IZsCAAJ-2rHVcghn0XglXlsSh6VSKFDPcqO4gptg5MnkGqvrtQQQ6CFdXNhYnStog8-GGbDD6v2UU3iJdHRXOaEBwB18hc4TJlMJJSkEL-_M9u_2TpyjPb4SSZXOJCOBvHNhFcFkePg4hc4fOYRwcZhwzkvnM9aaNHh5bzknRg_3SXBIycAZx0Dw1CTMrwj0aiXqJlyVFZbsDvsF9glUz4n5qa_73KZmYPhp5xmbQaydaNORQSHrY0UPcKBujcjAgsNCMJSyv4qpDL2Amo7rnC9TbBNr8Gdlt8lbHFI1aHa0is_H5SMAxiKJOjODEAKTDUWHoZO7E16zsH0nZKPkdH2Ko1lHTx4d05gOnW03Zs07Kra2af-gx5pwToVrbgsdl6NeKCjVi3kE3oxg8Q_fl3wKcaDapF_NpZIqQ-BIlrhGRlbAauHK_88duJQBCGoKBGBg67mDXCgPUz1tDaVaaBoQaXuTPcR7F1hGyiY6qyzE7Xx1cOIUDgZZsyyKs20RpIX1MoFbqKposExhPJGCkQzUhr_DmRslZHsABdyqIFv5-VRV3Uucf5XrmAGkAFbw-saDooNT6Utg=w727-h969-no?authuser=0)
OP, I know you sold your car. Whatever was the solution? Also, you interchangeably used open and closed with vacuum on and off. To be clear, vacuum=closed=quiet, atmosphere=open=loud=resting position. Sounds like yours were stuck vacuum=closed=quiet. So, you couldn’t have a vacuum leak. Was the programming not taking? Was it a stuck COV? Were the valves mounted backward in the exhaust?
