Power folding side view mirrors...
That 's not the standard sport design mirror, which is where the confusion arises. The option on the GTS to have the SD mirrors lower painted body color does not exist by itself. You need the folding mirrors for that. If you ordered the carbon fiber top, then it defaults to the body color lower. There is no option to get the whole mirror assembly body color, other than with folding mirrors. Thanks Porsche for making this so easy to understand.
Didn't have them on my first 991.2, but ordered them on my second one. Love them. They do make a difference in a garage (or parking garage), and just seem "polite"—no bad thing for a new Porsche when it's parked.
Do prefer the optics of the Sport Design mirrors (depending on how they're painted), but I felt the power mirrors were a better choice for me.
I bought the sport design mirror assemblies, had them painted and paid to have them assembled and installed. A lot of expense just to get rid of the power folders that came on my GTS. Did not like seeing them folded or care for their looks in general. That's my reason FWIW.
Agreed that the SD mirrors look better but without power folding, wouldn't go for them. Of course after checking them out closely, it is obvious why the folding action of the SD mirrors can only be accomplished manually.
The 15 GTS came with all matching painted SD mirrors unless you select the Folding option. The 16 GTS came with the lowers in flat black unless you opted for High Gloss Black or Folding.
Received 3,365 Likes
I wanted the lowers painted to match on my 2019 GTS but as discussed here that was not an option on the configurator; however, I knew I could get them as a CXX option so I had my SA look into it: $1400 to have the lower sections painted to match the exterior. My my SA said I should pass since the Black looks good and if I changed my mind I could get them painted for less and as of right now I like them Black.
I suspect this debate is already raging, but: any moans, groans, or questions about the 992 side mirrors? I have an uneducated opinion and suspect I should listen to all arguments, one way or the other.
That said, I found this thread because I was searching for a way to have SD mirrors that have elec fold... *kicks rocks; walks away*
GPd
GPd
Check the 992 Forum, where I suspect they are debating just about everything.
Rocky Mountain High
Does anyone know if a carbon fiber shell is available for a power folding mirror? I wonder if it uses the same shell as the standard mirror.
