Help - misshift - did I damage my engine?!
Second gear tops out around 70 mph. Were you going faster than that?
Perhaps it is worth mentioning that good hand positioning on the shift **** can reduce the chances for this type of problem. To shift 3 to 4, have your hand directly over the top of the shifter. To go 3 to 2, your hand should be on the right side of the ****. Etc. I have quite a bit of trouble with the 7mt myself, especially going 4 to 5, which seems to have a narrow gate, often causing the selection of 3rd instead of 5th.
I wouldn’t sweat it.
Thank you so much for all the responses! Can an Indy shop pull the rev data or does a dealership only have those tools? When I go in to do the oil change and get a sample, I will ask them for that as well.
With regard to the speed question above, I honestly can’t remember but I’m sure I was going at least 70mph.
It wasnt clear from the OP. Did you let go of the clutch and engage the gear while you were over revved? If not, then definitely dont sweat it. If you put it in gear then definitely check the oil and filter as others above have wisely stated.
Being a bit paranoid isn't a bad thing. Would bet you are fine. Keep listening and do the checks as discussed above. Cheap insurance for your angst. If it grenades, they're going to run the numbers on you though, so just be prepared for that. I'd just chalk it up to learning and good motivation to focus on the shifts in the future.
When getting used to the gates a few years ago, I quickly popped it into reverse from a stop instead of first, in traffic, on an incline... Let's just say, while it could have gone a lot worse, it humbled me. Never happened since!
Yes, I did put it in gear unfortunately.
With the stock shifter it kept wanting to go 5->4 or 3->2 during upshifts. I never had this happen at redline but during normal driving, but thankfully never had it rev past 6k and never disengaged the clutch. I went with a weighted shift **** and this virtually eliminated the problem. I know it will likely wear out the shifter mechanism over time, but much less likely to over rev the engine.
I'm sure you will be fine. Now go and buy a numeric shifter and cables so you can make sure it doesnt happen again
Received 5,415 Likes
You don't need a over rev report. You HAVE over revs. Why do you need a report to tell you such?
You don't need a Blackstone Labs UOA. One report won't tell you anything. 4 reports will start telling you something. Only do it now IF you plan to continue and like this kind of data (as I do).
Please don't take this the wrong way, but you need to increase your "situational awareness" when driving. I sense, from many of your replies, that 'you don't recall' what was going on at any particular time. For example, had you been in Sport Plus, and mistakenly chosen a lower gear, when you really wanted a higher gear, you would have audibly heard an auto-blip in the RPMs, and would have then known you selected the wrong gear by mistake and kept the clutch in and re-gated. Yes, this all happens in a mir second.
Rev limiter is your friend, engine cuts out and you will feel loss of power. You cant damage the engine that way.
unless you are over reving constantly
I believe 2nd tops out at 77mph and T revs to 500rpm more than base.
the shift gates are really close. If you sre grabbing the shift **** then its easy to go in an unintended gear based on your wrist position. When going in 3rd to 4th use your finger tips, they should line up.
i once went into reverse when I wanted first because I had a little pressure on the shifter.
this manual is not for racing, thats what PDK is for
Base and T redline are identical at 7500 rpm. Just checked again, you almost had me excited
Still don’t see the problem, just trying to find/solve a problem that doesnt exist.
the car has zero issues
if any damage is done its done
either sell it immediately or stay awake worrying about it for the rest of amazing ownership
worry about problems when they actually appear
