Can you push a pdk car in neutral?
Old Jul 24, 2018 | 01:13 PM
wareaglescott's Avatar
wareaglescott
Default Can you push a pdk car in neutral?
When I was weighing my car the other day I have some wood platforms I get the tires on and then put the scales in front of the ramps. My normal procedure with my other vehicles is just putting the car in Neutral and pushing it forward the 12-16" to get it on the scales. This is the first time I have attempted to push a car with PDK transmission. When I put it in N and opened the door to get out it seemed the parking brake automatically set. Car seems to be smarter than me in an attempt from keeping it from rolling away. haha I was in a rush so I just ended up driving forward very slowly. (I prefer to push it because from outside the car I can see the scale and exactly when I am centered up).
Is there a way to simply put the car in N and push it around? Am I missing something. Looked quickly just now in the online owners manual and did not see anything.
Old Jul 24, 2018 | 01:53 PM
reacher's Avatar
reacher
Have you tried pulling both paddles at the same time? That disengaged the clutch in my GT3, not sure if it works on the regular PDK or if it stays in neutral when you do that. May be worth a try anyway.
Edit: Never mind, looks like you already got it in N but pushing it makes it lock up again? Not sure about that!
Old Jul 24, 2018 | 03:14 PM
arter's Avatar
arter
trying popping the electronic parking brake switch again?
Old Jul 24, 2018 | 03:21 PM
PorscheAddict's Avatar
PorscheAddict
Could you leave it in N and stay in the car (i.e., have someone help push)? I've used N to roll backward on a hill a bit while still in the car (PDK), but I'm not sure of your specific issue.
Old Jul 24, 2018 | 03:30 PM
81911's Avatar
81911
Hey Scott,
Yes, you can. Just open the door, put in neutral, release the e brake and you should be good to go. It it renegades, just re release it.
Old Jul 24, 2018 | 04:49 PM
wareaglescott
Originally Posted by 81911
Hey Scott,
The parking brake engaged a second time. I didn't mess with it much because my wife was there and I had her spot me going forward. Next time I will try it more extensively.
Most the time I am alone so staying in the car is not an option. However I don't see me needing to weigh it again so probably doesn't matter much anyways. I was just curious.
Old Jul 24, 2018 | 05:14 PM
LavaGTS's Avatar
LavaGTS
Pretty much what everyone else said is correct.. I must say I've sound this car more difficult to push in Neutral than a 5300 pound SUV.
Old Jul 24, 2018 | 05:46 PM
Jim M.'s Avatar
Jim M.
Opening the door with the car running is what sets the parking brake. Try lowering the drivers window, closer the door then reach in and release the parking brake. Then push to your hearts content.
Old Jul 24, 2018 | 06:01 PM
arter's Avatar
arter
+1
Old Jul 24, 2018 | 08:34 PM
Rennolazine's Avatar
Rennolazine
The manual rolls in neutral if you fart on it
Old Jul 25, 2018 | 12:38 PM
JAhmed's Avatar
JAhmed
Hey Scott,
Yup.
