Vektor Performance - Performance Headers
#91
Former Vendor
Former Vendor
Is your current inventory for sale with those changes?
#96
I am gonna dyno my carrera T Friday and will post the results. Sound is different then just having Akrapovic cats and pipe. Butt dyno on the top end deffo feels a difference. I am happy with the purchase and the way the order process went. I am using the same dyno I used after the Akrapovic install. The magic number was 383 so lets see what they give me.
Stay tuned
matt
Stay tuned
matt
#97
Stay tuned
matt
Stay tuned
matt
#98
I ordered standard so must have been in stock. They took 1/2 a day to install at my friends shop fs tuning. Came boxed with new factory gaskets etc. used advised T settings given and all is well and no leaks.
#100
Does the 991.2 require a 4 wheel dyno (or what ever they are called)? Sorry for the dumb question - I came over from the Corvette world and am not up on the Porsche stuff.
#101
Apparently, with the rwd 991.2s, there's some dyno mode you can put the car into so it won't freak out when the rears are spinning but not the fronts. But a safe bet is an awd dyno with the rollers linked.
#102
4 wheel dyno is not needed unless its AWD. For RWD, just disable traction control and go for it in 4th gear! You will get lights on for abs, traction and one or two others. They all self clear within 5 mins of driving and all 4 wheels turning at the same time. If you want to avoid the lights altoghther, then a 4 wheel dyno should work out fine.
#104
In route to the dyno
we see what these headers are all about
matt
matt
