Custom Install JK Automotive Design, East Coast Love..
The rear ALP sensors are really limited to where they can be placed due to the space provided by Porsche for the rear license plate. If you notice, the top of the bumper opening is more narrow than the bottom, see attached pic. Pink Dots are where top of plate should place sensors but, its too narrow to fit a plate and 2 sensors. So, in order to get them wider, JK actually mounts the plate slightly lower in the space to allow max distance between the sensors, about where yellow dots are.
The plate is designed to be angled and sensors are completely straight when mounted. No channeling of the bumper is necessary, the entire mount just screws in and screws off and when removed you would essentially never know it was mounted there
Also, don't lose sleep over a rear hit, it's quite a rare occurrence.
I have never been hit from the rear, but..
1. If I have the car apart why not do it all
2. All it takes is one time and I'm in jail, so..
I have seen cops on tops of bridges and hiding on the on ramps so I think its location specific.
There are definitely places where they target the rear. I've been lucky..
A good shooter could probably breach this setup on the rear but keep in mind the car is moving away from him, so 1) he needs to quickly keep shooting towards other areas of the car before it disappears to get a reading 2) if the initial shot is towards the center of the car where the most reflective flat area (license plate) is, which I think would be the most common initial choice, you'd pick up on that and would slow down. No point in me speculating more but I do think they must find targeting an approaching car much easier hence the frequency of that vs the rear targets. Like you I'm at zero rear hits vs numerous front hits and I think we drive around in similar areas.
Looks great! I'm seeing an alp install this winter....
A couple of the completed pics and then final shots to follow.. Notice the Rennline Radiator Grills installed with ALP in front of the grills. Rear Plate installed with TX and Standard Sensor.
