Copying music to the internal jukebox?
Hey all,
I've copied 56GB worth of music onto a 64GB USB key. I can play music through the USB source (albeit initial indexing takes a while). Obviously the end goal is to copy that music into the Jukebox.
However when I do this, it's very very slow, looks like it would take 20 hours or so. After a couple of hours drive, it looked like this:
Unless I drive from Boston to Florida and back, I don't see a way to copy all the data. What's the trick?
(911 991.1 GTS)
(911 991.1 GTS)
AFAIK, Jukebox can only hold 10GB.
I thought Jukebox had 40 gb of memory.
As far as transferring that much data, it will take forever. Your best bet is to copy 20 - 40 songs (or whatever, but a smaller amount) at a time to another thumb drive and copy that to your Jukebox. It's gonna take time, but really the only manageable way to do it.
Bassman37 (09-24-2021)
Rocky Mountain High
Follow the instructions in this thread:
https://rennlist.com/forums/991/8447...y-for-pcm.html
It worked perfectly for me. It’s easy and it doesn’t take too long.
